Trailer wiring question
   / Trailer wiring question #1
RollTideRam
Veteran Member
Hartselle, Alabama
Kioti DK 4710 Cab
I have a utility trailer with sideboards to haul mulch and gravel etc. It is wired with a seven pin connector. All the lights work and the brakes work correctly until I put my truck in reverse. I can then feel the brakes locking up. What would cause this? I can unplug the trailer and back up with no problems. JC
   / Trailer wiring question #3
Maybe also check any connections for corrosion. Every so often my trailer/camper lights do funny things and it's always been a connection tied into the original wiring.
An RV dealership is a good place to go to get your type of problem fixed.
   / Trailer wiring question #4
Just a guess - but maybe your backup lights are wired to the trailer brakes??
I believe the backup lights are to use the center pin on a 7 pin connector but you need to check Egon's wiring schematic.
   / Trailer wiring question #5
Prossibly a loose wire in one of the plugs causing the brake and backup light wires to cross. If your trailer doen't have bu lights, I'd check the truck plug first. You could check it with a 12v tester w/o taking it apart following the wiring diagram Egon posted.
   / Trailer wiring question #6
Check to see if the trailer plug is factory T-Plug style with factory style connectors or if it spliced into the wiring.
If it is a factory plug, a couple of things could be wrong. Without knowing make and model of the vehicle, it would be had to say if it was a tail-light assembly or some other factory connection.
If the plug is spliced into the truck, the reverse light may be tied in erroneously. Easy way to check. Get a voltmeter or test light, Turn off all lights, place vehicle on level ground set brake, chock wheels,turn ignition to the run position without startingengine and place vehicle in reverse. Remember. Engine Off, vehicle on level ground set brake and chock wheels!
Move to rear of vehicle and check plug-in with test light or volt gage using the 7-pin wire chart.
You should not have any voltage on any terminal except 12-volt pin #4 and the center pin if it is wired for auxiliary power. If you do not find voltage on any other pin, then the problem is in the trailer wiring. If you find voltage check all splices and connections.
Check the Brake Control at the fuse panel or where it is spliced in to the wiring. Use a wiring diagram for your vehicle for color determination, this can be found in the owner’s manual or a repair book. More than likely, the reverse switch is wired into the electric brake wire somewhere.
If you cant find any issues with the truck check the wiring on the trailer at the plug connector, If it is recently converted from a flat or other pin style it could have a stray wire from the #4 pin or center, making contact in the plug connector. If this check out then check the brake wiring connections. One of the hubs could be improperly wired so when you go to back up one of the brakes drag.
However, the obvious question may be, do you have surge brakes?:eek:
   / Trailer wiring question #7
''However, the obvious question may be, do you have surge brakes?''
That crossed my mind, then remembered he said when he unplugs the trailer it backs up ok.
Sorry to ask this question then abandon all replies. I'm off work on Monday and will start with the trailer plug. Forgot to mention that I have no problems when pulling my other trailer. Thanks, JC
   / Trailer wiring question #9
Do you have to readjust the controller for the different trailers?
   / Trailer wiring question #10
Does your other trailer have brakes ? If so, then I would say that the trailers themselves are wires differently.
Don't get mad, cause this is all in fun, but if you were a tiger man you could figure this one out. :D
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
