Trailer towing
   / Trailer towing #1
aggc
Milmine, IL
Can someone tell me what the correct method is for towing a 5 x 10 utility trailer behind my tractor? Should I hook the trailer up to the drawbar that's attached to the tractor frame or to a towbar attached between the arms of the three point hitch? Is one method preferable? I'll be towing up and down some hills if that's a consideration.
   / Trailer towing #2
I always hook to the drawbar attached to the tractor frame. To me it is just more stable.
I only hook to the 3pt hitch drawbar when I am moving the trailer a short distance.
   / Trailer towing #3
I've done it both ways. As has been said, the "swinging drawbar" attached under the tractor's differential is more stable. In some cases, having the trailer farther back, though, is an advantage enabling sharper turns. Using the 3-point also makes it simple to back up to the trailer and raise the 3-point to hook up. Of course, you need to have some device to prevent the drawbar between the lower links from turning, and you need to either keep a heavier load in the front of the trailer, or have chains or some other method to keep the front of the trailer from rearing up and raising the 3-point.
   / Trailer towing #4
From a safety standpoint... the drawbar is the only way to go.
   / Trailer towing #5
Most of the OEM manuals I've read over the years require drawbar hitching because they don't always supply the three point hitch option(s) and don't know that manufacture's strenght of materials. Therefore, it would become
a product liability for recommending unknown specification of another manufacturer design.
   / Trailer towing #6
All I know is that if you tow with the 3 pt. hitch and something goes wrong the tractor could flip backwards. That wouldn't be the case using the drawbar which is below the rear axle.
I'm not the tractor police... but if somebody is asking what is the best method for pulling a trailer... I'll tell them the drawbar every single time.
   / Trailer towing #7
In keping with that.. there ae 3pt stays and locks to keep a 3pt drawbar from spinning.. and to keep it locket in a position simialr to the fixed drawbar. ( some tractors don' t have the fixed drawbar .. however if they do.. it's a hands down contest as to which to use.. )
Soundguy
   / Trailer towing #8
Hello all,
I've pretty much decided on the BX24.
I also have a 6" bandit chipper that weighs in around 2000lbs with trailer. I need to move it around my property (about 2 acres)and my silverado crew cab 2wd gets stuck.
Can I pull the chipper with a hitch on the BX24?
I won't be moving it around much, but I would like the option.
   / Trailer towing #10
asylum575 said:
Hello all,
My B7800 is rated to tow 3500 lbs so I would assume your BX24 could pull 2000 lbs easily
2016 GMC Sierra 1500 SLT 4x4 Crew Cab Pickup Truck (A50323)
2016 GMC Sierra...
2013 Ford F-450 Altec AT200A Bucket Truck (A50323)
2013 Ford F-450...
72'' Bucket (A47384)
Swict 84" Bucket (A50121)
Swict 84" Bucket...
40' High Cube Four Multi Doors Container (A47384)
40' High Cube Four...
