Trailer tires
   / Trailer tires #1
ronchp
Bronze Member
Limestone, TN
Mahindra 3616
We bought a 2012 horse trailer this spring and last week had a blowout. Got it back on the road pretty quickly. The date code on the tires were all 2011 manufacturer so I replaced them all. The name plate data on the trailer lists E load range at 80 psig. The tires I purchased are F load range, which has a higher load rating at 95 psig. I intended to run them at 75-80 psig when loaded but my co-workers said I should keep them at 95 psig since that is the tire rating. What pressure would you recommend?
   / Trailer tires #2
If I'm running a long distance empty I put like 20 - 30 lbs in. Makes for a smoother ride. As the weight increases I add more air to the point where max weight = max pressure. Most of the time for just local runs I run with about 3/4 pressure as a short run slightly under inflated isn't going to do any long term harm. I rarely run my trailers at max load.
   / Trailer tires #3
I'd compare your new tires load rating @ 95psi with your old ones @80psi. As long as the new tire's # capacity is higher, then I'd consider running 80psi, vs. 95psi.
I understand what pms is doing. I do something similar with a light utility trailer that mostly only sees duty these days near home. However, with my 23' travel trailer, I always run those tire within 2psi of maximum.
For long hauls, even a low-cost IR gun is good for keeping an eye on tire temperatures (and bearings, differentials....) - higher load range tires tend to sag less compared to paper thin sidewalls on P tires, so one quick way to catch under-inflation early on a walk-around is rising tire temperatures.
With original tires, most utility trailers are designed to ride the best with roughly 1/4 to 3/4(ish) load. Running at max tire pressure long distance with an empty trailer transmits more shock loads to the trailer, and may lead to balding the centre of the tire. (Think personal use 1 ton trucks, that never see much/any load - run E's on those at 80psi, and the rears often centre-bald).
Stepping up LR, if you run those new tires at max PSI, IMO you will be transmitting even more shock loads into an empty trailer. Well, at least if your roads are anything like the falling apart roads around here..... but even good roads have RR crossings.....
If you regularly check and adjust tire pressure (vs load), then there can be benefits to doing so. If you are more the set once and check "whenever" (most people), then I'd tend to set OE tires at 90 to 100% of Max.
Rgds, D.
   / Trailer tires
I rarely pull it without at least one horse. When I had pulled it empty once before I lowered pressure to around 50 psig. Most of the time we pull 2 horses. It's a 3 horse trailer and we use the empty slot to put camping gear. I'll probably keep it 75-80 psig for awhile and watch for wear patterns.
   / Trailer tires #5
Do your co-workers also recommend running with the Max. load all the time?
There are charts that tell you what pressure is recommended for what weight but they are hard to find.
MOST trailer tires are rated for more weight then the trailers are so you should never need the Max. air.
   / Trailer tires #7
5 years on the tires. I still have the original tires on my 2001 three horse trailer. But my tires are LT tires and not ST.
   / Trailer tires #9
For those who vary pressure to match load, do you have an air compressor you also haul? If you do have compressor you transport could you share the setup is it run off electricity or small gas unit?
   / Trailer tires #10
I match the pressure before I go and pick up the load. If I don't know what the load will be the tires go to maximum pressure.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
