Trailer Tire Question - super single?
   / Trailer Tire Question - super single? #1
Chris611
I have an '08 Loadmax 14k lb 25' gooseneck. It has the original Freestyle tires on it. Last night I blew the sidewall out of one of them. After reading, it seems like 5 years is the limit (or over the limit) for the life of ST trailer tires. I am going to replace them. I thought I remember reading on here some time ago about some super singer or heavy duty single trailer tires. They were basically single tires for a 21 or 22k lb trailer that ran tandem singles. I have googled this and can't find any such tire. I would be interested in getting tires that have a much higher load rating so I don't have to worry about tire load, speed, etc... Sort of over do it and forget it. Anybody got any ideas for a 235/80R16 or a 235/85R16 3500+ load rated tire?
   / Trailer Tire Question - super single? #2
You would have to step up to a 14 ply tire to get a higher load capacity in a 16 inch tire.You could get some new wheels for a 17.5 inch tire which are usually 16 ply with a 5k or so capacity.
   / Trailer Tire Question - super single? #3
I run the goodyear load range G tires but they are pricey. Think your looking at 1000-1500 for set of 4. But they are best 235/85/16'a I have used. Ran out of tread in about 9 years and change them to a new set. With the loads I run they are worth every penny. I tried a set of 10plys and they made it a couple months before they blew out.
I have 2 8K axles and usually running 15-20k every time it leaves which may be daily or only once a month depending on weather. Lately been using it to haul a 1650gal water tank. As its been really dry around here.
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
1261 (A50490)
1261 (A50490)
20ft Driveway Gate (A51573)
20ft Driveway Gate...
Pallet of (11) 10 Lug Misc Wheels (A51573)
Pallet of (11) 10...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
