Trailer Surge vs Brake Controller
   / Trailer Surge vs Brake Controller #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I have a tandem axle trailer and currently use it with a brake controller. I'm wondering if I could convert it to a surge brake set up like the UHaul trailers so I can tow it with other trucks that dont have a brake controller installed.
Is their a weight limit for surge brakes? The trailer is rated at 7000# also.
   / Trailer Surge vs Brake Controller #2
I honestly don't know, but I think there might be a legal issue.
Even if they are legit you might have registration problems if the work isn't done by someone who can legitimately re-certify it.
I'm assuming that the type of braking system is recorded on the registration, but this is something you should check into at your PennDot office.
   / Trailer Surge vs Brake Controller #3
If the trailer doesn't have a title I doubt there would be any legal issues with it. I personally like surge and they will work well if properly maintained and adjusted for the weight you will be carrying. My boat trailer is surge and they work very well.
   / Trailer Surge vs Brake Controller #4
I think all boat trailers have surge brakes because of the fact they are backed under water. Not too good a thing with electric brakes. I'd prefer electric over surge for regular trailers for the fact they have finer adjustment of how you want them to grab.
   / Trailer Surge vs Brake Controller #5
I like my electric brakes..more control over the braking action.
   / Trailer Surge vs Brake Controller #6
I saw one trailer a while back that had one axle surge and one axle electric...
   / Trailer Surge vs Brake Controller #7
Unless you have something like the max brake or its equivalent the surge will give you more brake over a wider range. Example being you set your electric controller for a comfortable effective gain but if you have a panic stop you may not have enough. The surge will try to bring you down as fast as what your giving the tow vehicle. Most people don't realize they can change or adjust the master cylinder spring for the trailer weight to make the surge sensitive.
   / Trailer Surge vs Brake Controller #8
We see some electric brakes making the way to the marine trailers. Not very many but they are showing up on heavier boats, 15,000# and more to aid in backing down the ramp, one thing surge brakes are not good at.
If you are serious about switching from Electric to Surge plan on spending some money. It will run you $750 to $1000 dollars for a tandem axle trailer by the time you buy all the lines, backing plates, drums or disc, calipers if you go the disc brake route, back up solenoid, and then convert the tongue to a surge coupler. Not going to be cheap. Would be cheaper to put 10 $60 WalMart controllers in all your tow rigs.
Chris
   / Trailer Surge vs Brake Controller #9
I don't know about other states, but in Texas, Section 547.402, 3, c of the Transportation Code says surge brakes may be used on trailers that weigh 15,000 pounds or less, so I don't think we have to worry about it.:D
JOHN DEERE HX14 LOT NUMBER 272 (A53084)
JOHN DEERE HX14...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
Quick Attach EZ Axe Skid Steer Tree Shear (A53472)
Quick Attach EZ...
Electric Concrete Mixer (A51573)
Electric Concrete...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
