trailer SPRINGS, going over instead of under
   / trailer SPRINGS, going over instead of under #1
Boeing
Platinum Member
Botetourt, Va
kubota L3010
Fellas,
I was fussing last fall about my trailer being so low when I loaded it up with Tractor/loader and bush hog. The rear of the trailer is not more than 5" off the pavement. I called the trailer company who made it and was told that it has 2500# axles and 3 leaf springs.
I just went to Northern Tool and bought 4500# springs (4 leaf) While there they had a "kit" which included brackets for the ends of the springs, bushings, a center bracket, shackels etc. and drawings of the springs ABOVE or BELOW the axle.
HERE is the question guys: My springs are currently UNDER the axle.....WHY can they not be set OVER the axles giving me at least 3" higher ground clearance? There is a metal plate that the springs set in and it is cupped to sit on the round axles.... I don't think it cares if it is above or below the axles. Can anyone advise me here.....am I missing something important? I would like it higher as the road into my property is a bit rough and 5" clearance is going to bottom out a few times...dragging taillights, license tags etc.....not to mention perhaps bringing me to a grinding stop.:mad:
   / trailer SPRINGS, going over instead of under #2
First, is that metal plate the springs sit in welded to the axle? Some trailer axles and springs are designed so you can put the springs over or under the axle, so some are not I once thought I was going to move springs from below the axles to above them on a travel trailer I owned, but it couldn't be done with that one.
Secondly, you say you have 2500# axles and you bought 4500# springs. How much weight do you put on that trailer? Are your tires, wheels, spindles, bearings, and axle tubes capable of handling the weight. When we had a 32' fifth-wheel trailer with 3500# dual axles, I was running 7,300 pounds on them; a bit overweight. So I went to the manufacturer and asked about doing the same as you; add a leaf to the springs, but I've have still been overloading the other components. What I actually did was replace everything below the frame. We put new 5,200# axles, using axle tube made for 7,000# axles, new wheels, bigger brakes, and new tires.
   / trailer SPRINGS, going over instead of under #3
What you are trying to accomplish is a spring over axle conversion, people have been doing it on 4wd trucks for decades. I have a couple trailers that I have done it on.
I would use the springs that came on the trailer, the others will overload the axles. You will need to purchase another set of weld on spring perches since your axles are probably cambered and therefore cannot simply be turn over. Weld the new perches on top of the axle, move the springs and spring plates above the axle, and bolt it all down using the original u-bolts, that's all there is to it. You will probably gain more like 4-5" of lift instead of the 3" you mentioned.
   / trailer SPRINGS, going over instead of under #4
There is no problem at all moving the springs to above the axles. Just weld on new spring perches and set the axle under the springs.
Your new 4500 lb springs are probably a good idea too. It's not the spring that overloads the axle, it's the weight you put in the trailer. Old springs can sag and even break. So go ahead and use your new ones and place them over the axle, Good plan!
   / trailer SPRINGS, going over instead of under #5
True for a static load- but for a dynamic load that is not true. The axle capacities must be derated if NO springs are used so I would imagine too stiff springs would also require some derating.
An impact (pothole) could bend the axle that may have been a non issue with properly compliant springs.
I'd return the springs, move the axles under the original springs and either weld on new spring seats or, if they are Dexter axles, they sell a conversion kit that doesn't require welding.
http://i.b5z.net/i/u/1080235/f/Trailer_Height_Adjustment.pdf
   / trailer SPRINGS, going over instead of under #6
I can't understand why anyone or any company would suspend their load on the u-bolts when the load can be carried and leave the u-bolt to simply hold things together. When I joined a company a few years back there was a lot of grumbling about a particular trailer breaking down a lot, as soon as I saw what the set-up was I suggested they rearrainge the orientation so that the axle carried the springs instead of hanging them, end of problems and a more level trailer to boot.
   / trailer SPRINGS, going over instead of under #7
I agree. The physics of a "hanging" axle really don't make sense. It's just a compromise for a lower ride height, if that is needed. But a terrible design.
   / trailer SPRINGS, going over instead of under #8
No springs, is a way different case than stiff springs. I have used 5200 lb springs on 3500 lb axles with no issues at all. None of them ride very well when empty, but that's the nature of a short leaf spring with no shocks. And, old springs can break if they are bent or rusty, or just old. I've had it happen. It's a good idea to replace old springs and the U bolts whenever modifying trailers. Further, if you do overload the trailer at some point, it is less likely to bottom with stiffer springs. Bottoming is a shock load. So, stiffer, in an overloaded situation is less likely to break an axle because it is less likely to bottom with a heavy impact. But it will ride rougher with a medium load.
If you have a travel trailer, you can match the springs to the load fairly well, but then you might go to Baja and pound through hundreds of pot holes. If you haul a tractor, as I do, the trailer gets towed empty at 2000 lbs and loaded at 8000 lbs. It's also easy to take a 2000 lb rated trailer to Home Depot and get a "few" bags of concrete and some tile. Next thing you know you've brought home 4000 lbs of stuff. Always a compromise. But, bottoming is not your friend.
   / trailer SPRINGS, going over instead of under #9
Certainly is. Apparently you missed the key word "some".:p
Did the OP say anything about bottoming? No- he wasn't looking for more capacity he was looking for more ride height.
Two different problems to solve....stouter springs just to gain height isn't the correct way to do it. My:2cents::drink:
I did it.....now we wait to see what I have caused. I dropped the axles, the springs were already the 4500# 4 leaf....so I DID NOT change them. I DID flip the axles 180 degrees so bottom is UP now. The spring plate WAS welded on the bottom to keep the springs under the axle. I rotated it to the top and now the springs are ABOVE the axles. Put it all back together and the trailer bed is about 5 inches higher than before. I LOVE it. I found all bolts torqued (or rusted) about 120 LBs so I soaked them all in penetrating oil during removal and retorqed them about 20# "tighter than tight". I'm guessing about 100#. I will really like the height when I get to the gravel road in Virginia.
Thanks for the input and advice. :D
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
2005 Jeep Wrangler 4X4 SUV (A53424)
2005 Jeep Wrangler...
Scag Mower (A50324)
Scag Mower (A50324)
2020 INTERNATIONAL LT625 TRI AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
