trailer size for JD 4005 with bush hog pulling with F150
   / trailer size for JD 4005 with bush hog pulling with F150 #1
hdlabs
columbia sc
John Deere 4005
Have an F150. Need to get trailer long enough to fit a JD 4005 (129 inches long) and a woods 5 ft bush hog. Not sure how long it is yet as I don't have tractor yet.
I had a massey ferg 240 and with bush hog.....it was too long for 16 ft trailer. Looking to upgrade trailer and not sure whether to get 18 or 20 ft.
Thinking of a 16 ft with 2 ft dovetail......
Don't want overkill of trailer but want it to be big enough to safely transport.
Tractor has front end loader.
Thanks for input.
   / trailer size for JD 4005 with bush hog pulling with F150 #2
Measure out the rig and add 2' minimum.
Chris
   / trailer size for JD 4005 with bush hog pulling with F150 #3
You may wish to have a bit extra length in order to balance your load so you don't overload your F150. I would be looking at a 20 foot trailer. This will give you about 3 feet fore and aft to center your load and get the needed (but not too much) tongue weight.
   / trailer size for JD 4005 with bush hog pulling with F150 #4
I suggest you hold off buying the trailer until you get your tractor and rotary cutter.
The 4005 (was 990) has enough PTO HP for a 6' cutter, by the way.
1264 (A50490)
1264 (A50490)
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
KUBOTA 1140CPX RTV (A51406)
KUBOTA 1140CPX RTV...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
71067 (A49346)
71067 (A49346)
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
