Trailer Security - Goose neck
   / Trailer Security - Goose neck #1
rgood
SW Iowa
John Deere 3020
Guys - Sorry to post this question if it's already been discussed - I ran a search to see and spent 25 minutes without finding anything.
I have a gooseneck trailer I'm going to be parking and want to ensure it will be secure - I've checked out the net about reciever locks etc - It seems to indicate your trailer can still be stolen - I'm now trying to figure out wheel locks etc.
What has worked for you?
Thanks!
   / Trailer Security - Goose neck #2
You are correct to assume that a gooseneck hitch lock is worthless. Once they get it onto a standard pickup bed, a chain will hold it in place until they get it home to saw off the lock.
If you have spoked wheels, run a chain thru each wheel side to side. That way they will have to crack the chain to get it to move. Cross siding the chains means thay can't remove the wheels to unlock it. I made up a hydraulic plug to apply pressure to the brakes so they are locked tight when the trailer is parked. Need a socket wrench to unload the brake pressure if you can find the cylinder insert.
Take home the jack handle if nothing else....
Thanks for the replies Guys - I'll move this discussion there.
rgood, I consolidated your posts over here in the Trailer forum. RobS
I just verified the way my wheels are designed I can not get a chain through them.
Is there a way to put a lock through the Jack somehow so it can't be jacked up - It was mentioned I could remove the jack handle -
Thanks!
   / Trailer Security - Goose neck #7
Barkless pitbulls.
jb
Paul, that is a good price on that Wheel lock - Have you used it?
   / Trailer Security - Goose neck #9
Noticed that the lock only accomodates up to 15 inch wheels--looks like a winner though.
Krone Big Pack 1270 Multi-Bale (A50120)
Krone Big Pack...
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
Westfield 80-51 Transport Auger (A50774)
Westfield 80-51...
KJ 10' Galvalume Corrugated Steel Panals (A50121)
KJ 10' Galvalume...
2010 Dodge Grand Caravan SE Van (A50324)
2010 Dodge Grand...
