trailer rear support
   / trailer rear support #1
gravelman
Platinum Member
NH
Kubota 2650
Hi folks..gravelman here in NH I have a Pequea deckover trailer...17 feet flat, 3 feet beavertail I need to know if anyone has made a support beam for the rear width of the trailer to support something 20 feet or a bit longer. It is 96" wide. Im just trying to figure out a way to fabricate something that will run the width of the very rear of the trailer for supporting long loads level. thanks much for any advice
   / trailer rear support #2
I bungee strap a 2by6 to my ramps . I use 2 when hauling hay to span the gap between them
ok, my ramps are slid in underneath so that is not going to work for me...besides i do some long distance hauling on interstates so it has to be solid and foolproof...
   / trailer rear support #4
weld a receiver hitch Upright to the bumper and make a T out of 2" sq tube
Now you are talkin...that is a great idea.... thanks very much
   / trailer rear support #6
I like the hitch-hauler idea. Make sure load remains' heavy on front side of axles or you may get tail wag.
ok, yes, i will just have to make sure it is heavy enough...could be substantial weight on it..thanks
   / trailer rear support #8
If you have stake pockets at the back of the trailer you can insert channel iron in the pockets and weld a cross piece, heavy enough to handle your load, to the tops of the channel. That way you can completely remove it when you don't need it.
   / trailer rear support #9
and foolproof...
yes, that would be a stronger way of doing it...and easy to remove...thanks much
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
2015 DODGE RAM...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
