Trailer Project
   / Trailer Project #1
tomh
Central Wisconsin
JD 3046R & White 6065
I am looking into building a trailer that will be able to haul my JD 790 and I have a few questions. Does anyone know where the best place to buy a set of axles is? Does anyone have a formula for setting location of the axles? Does anyone have any links that can help me find my own answers?
   / Trailer Project #2
Before buying my trailer I had thought of doing the same thing. I got as far as buying the axles and was negotiating on the steel price. That's when I found that the price of a complete trailer was far less expensive than the steel alone for the homemade trailer. I couldn't afford to build my own in comparison. I returned the axles and bought a complete trailer. /forums/images/graemlins/grin.gif
BTW: I was pricing the steel at a "wholesale" level because at the time I was getting a deal through my work.
   / Trailer Project #4
etrailerpart.com, dont know how cheap their pricing is but is good source.
Buying one already done is good advice but if you do your homework and can combine all of the good features of diff. trailers into your own and have the time, space, equipment to build your one theyre is nothing wrong with this project.
   / Trailer Project #5
Northern is a pretty good source for trailer parts. I don't know where you are located, but they have a store in Milwaukee. Nothern also has several books on trailer design and some premade plans that you can purchase. Sounds like one of these would be a good investment. With your tractor loaded and the attachments on, try for a 10% tongue load. Any less and you will have sway problems. More is OK, but then your pull vehicle will start to squat.
   / Trailer Project #6
First off I think Av8r2230 is right; probably cost more to buy the material and build the trailer than to just buy one. However, if I were going to buy axles to build something, I'd buy Dexter Axles myself because of the good luck I've had with them in the past. You probably have a local distributor somewhere in your area, and I've bought oil seals, brake parts, etc. from the one in Dallas, but I also went to the factory once, ordered two axles custom built and had them within 24 hours.
   / Trailer Project #7
I have to agree with Northerntools.com. Don't know the prices of too many other places but I know Northern has good quality Trailer parts, axles and anything else you might need to build one
   / Trailer Project #8
I had purchased the axles from a Northern Tool store near Monticello Minnesota. (I lived near there at the time.)
Edit: Darn spelling
   / Trailer Project #9
Like Bird I've had great luck with Dexter. I buy parts from both Dallas Axle and Redneck.
I'd recommend buying a complete trailer if it's a first time deal. However, if you're familiar with trailers and know what you want then chances are most likely to get exactly what you want you need to build it yourself.
I don't shop Northern for anything I wouldn't buy at Harbor Freight. I've found when it comes to quality items they're just as high if not higher than regular sources.
1. You can never have too many tie downs. You can buy tie downs at TSC or Northern or online. I prefer the shackle kind but to each it's own.
2. You can never have too much trailer brakes. You don't have to replace your axles to add brakes. They come as hubs and backing plates and are a simple install.
3. Your trailer can never be too adaptable. So I recommend having stake pockets along with the tie downs. That way if you need to haul loose bulk you can. But if you don't want to have solid sides then having stake pockets enables you to remove them.
4. Go for the biggest GVW you can find and handle. If you go seven thousand pound axles then you'll have eight lug wheels. That means your truck spare if you're towing with single axle one ton or three quarter ton will fit as a spare on your trailer in a pinch. (unless you have an older GM two wheel drive, some of them come with too small a center hole, not a problem on the four wheel drives)
Fifty two hundred and six thousand pound axles use a six lug wheel. Any four wheel drive six lug wheel will work in a pinch. So some half tons and some mini trucks will match up good.
You can get the thirty five hundred pound hubs in a lug pattern to match your tow vehicle if it's a five lug. This is true of the older GM five on fives and Ford-Jeep five on five and a halves too.
Empty I recommend a hundred pound tongue weight. If the trailer is going to catch a lot of wind, say like with a landscape tail gate, that needs to accomodated. Otherwise at speed you're going to get the wobbles. Wobbles are great for the circulatory system, all three of them, they'll make your heart race, you'll wet your pants, and if they're severe enough, number two too. /forums/images/graemlins/grin.gif
If you're on slick surfaces a lot then consider only putting brakes on one axle. I like the front but a lot of folks prefer the rear. What this does is keep one set of wheels tracking if the brakes lock up. When both axles lock up in a panic stop you can add the back end of your trailer to the list of things you're kissing goodbye at that moment in time as it goes by.
Trailers are wonderful. But sometimes I think we need to put a little more into picking them. It's a little like picking a spouse. The right one is a true blessing.
It is true you can buy a trailer for what it would cost you to build one. But only if you're not comparing apples to apples.
You'll have three times the trailer if you build one for fifteen hundred dollars versus buying a new one for fifteen hundred dollars.
   / Trailer Project #10
tomh; Just have to agree with Bird on the Dexters. All three of my tandems have them. The flatbed has 7K axles, and the other two have 3.5K. All three have the greasable hubs. You pop a dust cover off and shoot them full.
I have to take exception to your pickemup spare fitting though. /forums/images/graemlins/blush.gif My 8 lug from my F250, 01, don't fit or it may have been my '97 that wouldn't fit. At any rate, and I may be a little confused, one size in my experience doesn't always work. /forums/images/graemlins/crazy.gif
On a different website concerning welding, there is another guy talking about building his own. It does sound like fun, but he's finding out that it's actually cheaper to buy a new trailer than build one. Seems funny though, with most things it's the other way around!! /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
72In FEL HD Round Back Bucket (A52128)
72In FEL HD Round...
2015 JLGI Trailer (A50324)
2015 JLGI Trailer...
2014 TOYOTA 8FGCU25 FORKLIFT (A51222)
2014 TOYOTA...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
