Trailer plug
   / Trailer plug #1
dnetherland
Florida
Mahindra 4005
I have a 7520 4WD. There is a trailer plug to the left of the seat. It appears to be a Eurpopean configuration. Has anyone converted this to a 7 blade RV plug. I need to pull a heavy trailer in hills and need to find a way to wire in a brake controller for trailer brakes. I can't even find where the plug is in the wiring diagram in the tractor manual, so I have no idea what the function of the pins are.
DN
   / Trailer plug #2
I had one on my Kioti too. I wanted to get a plug for it but never found one. I didn't want to hack the wires up to make a new plug ....
   / Trailer plug #3
Go to a semi truck parts supplier. It is a std plug used on semi trailers.
   / Trailer plug #4
I changed the one on my 4110 to a 7 pin so I could use my equipment trailer and dump trailer behind it. I didn't put a brake controller on my tractor, just wired the pins for all the lights to work and left the brake and 12v charge pins empty on the plug for my uses. Would be very simple to use a 12v test light to check your current wiring and to wire the new plug.
   / Trailer plug
Thanks MtnView. Went to etrailer.com last night and they had the 7 pin round and wiring diagrams with instructions on wiring up an adapter. Will let you know how it works.
DN
Parker 250 bu Gravity Wagon / Seed Tender (A50515)
Parker 250 bu...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
KJ U-Type Shackles (A50121)
KJ U-Type Shackles...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
