Trailer plug on a 2305
   / Trailer plug on a 2305 #1
Rogator
Manitoba Canada
2010 John Deere 2520, John Deere 185, John Deere 155
I would like to put a two wire trailer plug on my 2305 for my sprayer. I plan on putting the switch in the spot for the cruise control. My question is where do I get the power from? Do I need to go to the battery or is there a place to get the power from under the dash. I would also like to add some extra lights in the future and will need power for these.
If anyone has added power to the rear of a 2305 or extra lights some ideas or pictures would be great. Thanks
   / Trailer plug on a 2305 #2
I would not pull power for a sprayer or more than one light though the factory wiring harness. You should add a new 30a circuit from the battery, switched through a relay, then you can feed your new accessories.
Here is a post where I detailed my light install, I also added a plug like you want...
http://www.tractorbynet.com/forums/showthread.php?t=69583
2023 CFG QNT45 Mini Excavator (A49461)
2023 CFG QNT45...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A51039)
2006 Magnolia Dry...
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
