trailer light connection for 5500 fwd
   / trailer light connection for 5500 fwd #1
tractorboy5500
Conroe TX
Mahindra 5500 4WD, 275 FEL
i was looking to see how hard it was to hook up a trailer light connection
"4-way" on my tractor, i noticed under the seat that there is a green plug, is there a adapter that the dealer sells for this hook up, mybe some one has done this before??? thanks for any reply's.
   / trailer light connection for 5500 fwd #2
I have a 6000 2WD so I am not certain that the wiring harness is the same as on the 4WD. However, on my tractor the unused "under seat" connector is 3 wires; ground, always hot, and hot when start/run switch is on. None of the three are connected to any of the lighting circuits. I wanted to use this to power a solenoid valve to switch chemical on/off for my sprayer. Dealer couldn't identify a part number for an opposite gender connector with pigtails. After enquiry here, MUSA said they would consult tech support. Received no further info. I just bought a couple of tap connectors and a cheap 2 wire male/female connector set and did my own thing.
2004 GREAT DANE 53FT REEFER TRAILER (A52141)
2004 GREAT DANE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2021 HYUN Elantra (A50324)
2021 HYUN Elantra...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52128)
2024 BCL...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
