Trailer latch
   / Trailer latch #1
nap61
I have a small (5' X 8') trailer that I use to carry my ZTR to a relative's house to cut grass. I have to pound on the latch to get it on or off the ball. Can I loosen the nut under the tongue so that there is more "play" for the piece to hook under the ball? Is that safe? If so, how much should I loosen it?
Thanks,
Norm
   / Trailer latch #4
You can loosen it as they say but I am wondering if you have a 1 7/8" coupler and a 2" ball????
Chris
   / Trailer latch
bcp and trailer,
Thanks for the reply and link.
Chris,
Unless the ball is misstamped, they are oth 1 7/8".
Norm
   / Trailer latch #6
bcp and trailer,
Chris,
Norm
Just wanted to check. I have seen it a few times before. I doubt the ball is wrong so just adjust the nut and be done with it.
Chris
   / Trailer latch #7
A little grease on the ball and the workings of the coupler help a lot, too.
   / Trailer latch #8
OH yes.. always keep it lubed and make sure that your ball stays tight to the mount. I have seen many trailers come undone because the ball itself unscrewed from the truck.
   / Trailer latch #9
Another lesson I learned the hard way when I was young and stupid is to make sure you get a ball shank that fits in the hole on your receiver stinger. It doesn't matter how tight the nut is, A shank that is too small for the hole will allow the ball to slop around.
   / Trailer latch
Farmer & trailer Guy,
Thanks. I will try some grease before I start loosening anything.
Norm
2006 Ford F-350 Forestry Dump Truck (A51691)
2006 Ford F-350...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
Year: 2018 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 225,027 Plate: Body Type: 4 (A51692)
Year: 2018 Make...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2013 Ford F-550 Passenger Bus (A51692)
2013 Ford F-550...
