trailer hitch on backhoe?
   / trailer hitch on backhoe? #1
mdbarb
Northern California
B21
I see many ads for trailer hitches on drawbars at the rear but I use the backhoe all the time and don't want to take it off just to move a trailer.
We have an enclosed trailer that gets storedin a very tight spot that requires every ounce of my backing up going forward skills when attached to the pickup.
I'm thinking if I could attache the trailer to a ball somewhere on the backhoe bucket - the tractor is shorter and MUCH more manuverable - I should be able to place that puppy on a dime.
But where, how to mount a ball on the backhoe without interferance problems?
Perhaps some sort of a slot/sleeve that the ball hitch could easily slide into when needed.
I know there are brilliant solutions out there amongst the TBN fabricators
   / trailer hitch on backhoe? #2
Seems like somebody did that but can't remember. Did you try a search? In a pinch one time I just found an old swivel link thingy that a ball stem would go thru then wrapped a chain around the bucket somehow that held well and just towed an enpty trailer around. Since then I drilled a hole in my FEL cutting edge to mount a ball ... very quick, easy and works great ... and I like pushing the trailer rather than pulling it!
Cheers!
I like the manuverability of a backhoe instead of a fel
I havnt founf anything in a search
   / trailer hitch on backhoe? #4
Ok, if it's been done or thought of, this is the most likely your guy: GuglioLS.
Hope that helps, cheers!
   / trailer hitch on backhoe? #5
I made a simple device that I attach to the center of my loader bucket and it has a ball on it. I now see that they sell these.
Mine is simple, but you would probably have to have a welder.The ones you can buy use a screw clamp to hold them in place.
for mine I used a pe=ice on steel angle iron and set the ball on one end and the other end drilled a small hole 3/8 in the bucket . and used a bolt to attach it. I just reciently welded the bolt solid and drinlled it out to take a lynch pin. This makes it easy to put on and off.
My trouble is remembering where I put it last..LOL
The advantage to this type is that I can see the trailer and its much easier to jog it around.
I could get a picture if youd be interested.
Allan
   / trailer hitch on backhoe? #6
</font><font color="blue" class="small">( I like the manuverability of a backhoe instead of a fel
I havnt founf anything in a search )</font>
I don't understand this comment - there is a difference between a real backhoe, a Tractor-Loader-Backhoe, and a loader tractor, but I can't tell what you are prefering....
Anyhow, there are several clamp-on hitches that will work if your trailer is not too big a load. Look to the advertisers here, or anyplace that sells loader attachments such as pallet forks, esp the clamp on forks. I've seen a dozen different copmanies that offer such.
--->Paul
Paul
I have a Kubota B21.
What are the differences between a real backhoe, tractor loader backhoe and loader tractor (as they relate to this topic)?
I have looked online but not seen what I am looking for - a simple receiver for a ball located somewhere on or near the backhoe bucket.
   / trailer hitch on backhoe? #8
</font><font color="blue" class="small">( Paul
I have looked online but not seen what I am looking for - a simple receiver for a ball located somewhere on or near the backhoe bucket. )</font>
I see. I got a bit muddled. /forums/images/graemlins/smile.gif
A real backhoe is on tracks, has the backhoe arm, and that is all. Doesn't look like a tractor at all, some will call it an excavator I believe.
I thought you were talking about a TLB you have - like the Case or JD units, they are a beefed up tractor with a dedicated construction loader on them, dedicated backhoe on the back. There is no 3pt hitch or pto, the front axle is industrial, the hydraulics are beefed up......
A loader tractor is what you have - with a 3pt or frame mounted backhoe on it.
When you said you wanted to be more manuverable & mount a reciever hitch on the bucket, I thought you meant you wanted to put the hitch on the _loader_ bucket, and be able to back your trailer around. It is much more manuverable that way.
There are many companies making such clamp-on reciever hitches.
I'm not aware of a hitch that goes on the backhoe arm/bucket. That would be rather stressfull on the geomotry of the arms & hydraulics, and may not be a very good idea.
--->Paul
   / trailer hitch on backhoe? #9
A Kubota B-21 is a TLB.
I would simply weld on a plate to the upper rear lip of the BH bucket and install a trailer ball onto that with the bucket levelled.
I welded a clevis hook onto the BH of our L-39 TLB as seen in the attached photo, something similar with your B-21 is possible with a ball hitch... /forums/images/graemlins/wink.gif
   / trailer hitch on backhoe? #11
Hopefully this is what you are looking for.click here
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
WOLVERINE PT-16-01C 3PT HITCH ADAPTER (A60432)
WOLVERINE...
UNUSED SDLANCH SDLE20 EXCAVATOR (A60430)
UNUSED SDLANCH...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
