Trailer Hitch for 425
   / Trailer Hitch for 425 #1
bubenberg
Platinum Member
Bucks County, PA
PT425, Kubota L2050, 3 hydrostatic Exmark mowers. Z21D Kubota ZTR, 2 Kunz acrease wing mowers, 1 rough cut kunz mower, one vintage grasshopper ztr, one vintage gravely ztr, various large garden tracto
<font color=green>Subject: Re: PowerTrac Customizations - 1845 hitch
Hitch in primer - photo attached.
Having owned the Power Trac 10 days, and already cut of something and welded on something else, I suspect that I may keep it. Certainly I made returning it for a refund a bit unlikely.
But, no buyer's remorse so far.
Next project is to dismantle another old Reese hitch and mount the receiver on a quick attach plate to hook things to the front.</font color=green>
Charlie, almost twelve month later we followed your suggestion and mounted an old but sturdy ??? truck trailer hitch to our pt. the only modifications are: we added 5 inches to either side in excess of the 425 engine compartment. rather than welding the hitch fast we bolted the hitch (via welded on angle iron stock) to either side of the engine compartment.
i got be too late last night to test pull anything real so we used a two ton tire jack, well the bolts did not budge.
thanks for the suggestion and pictures of your hitch adaptation invention/construction/painting process.
now i have to solve the electrical power problem because i hate to work on the road in the dark, without some sort of a strobe light in the rear. the additional lights we installed in the corner of the ROPS and the roof are great but seem to draw too much juice. i know i told this story before, now i need to act on this problem, because i also like at the same time to start my engine in this cooler part of the year without any problems.
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
2009 Freightliner Columbia 120 Winch Truck, VIN # 1FUBA5CK39DAM2731 (A51572)
2009 Freightliner...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
New/Unused 78in Quick Attach Rock Bucket (A51573)
New/Unused 78in...
