Trailer Help
   / Trailer Help #1
Warwagon
Bronze Member
Graham, WA
Kubota L5030 GST
I am in the process of looking at goose neck trailers in the 20,000 lb. GVWR area . I have a choice of two 10,000 axles with duals or 3 7,000 lb. axles with single tires. What are the pros and cons of each? Any help would be appreciated.
Kevin
   / Trailer Help #2
Three axles mean a lot more wear on tires. You also have to be very careful with inspection stations. Let's say you have ten ply tires and they're rated at three thousand pounds each. Your axles are rated for twenty one thousand pounds but your tires are only rated for eighteen. /forums/images/graemlins/blush.gif
A lot of three axle trailers run on axle as a non brake. The seven thousand pound brakes are a lot smaller than those on the ten thousand pound axles. So you could be running less brakes, ie, more risk.
If you're towing with a single axle one ton or a three quarter ton then a three axle trailer can share the truck spare saving you carrying a separate spare for the trailer.
A dually or one ton with eight lug wheels will share tires and wheels with the dually trailer.
I'd go with the dually. Bigger brakes, more rubber, and ten ton is a lot of weight back there when it gets a mind of it's own.
   / Trailer Help
Thanks Harv and Bird, I hadn't seen the above thread, I quess I will be looking at the tandem duals.
Kevin
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53473)
2017 Yale GLC050VX...
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
2007 Case 580M Series 2 Loader Backhoe (A53117)
2007 Case 580M...
