Trailer GVRW
/ Trailer GVRW #1
hallj86
Branson 3515H
Will a 7K GVRW trailer be enough to put my 3515 with FEL and a box blade? The trailer is 20' with ramps.
/ Trailer GVRW #2
Yes should be fine (brakes on both axles ) ...:)
/ Trailer GVRW #3
I'm guessing that you meant GVWR (gross vehicle weight rating) instead of GVRW, and I would think you'll be within the weight capacity of that trailer. Naturally, there are a number of considerations besides weight when it comes to trailering.
/ Trailer GVRW #4
I would do it in a heartbeat based on what you are considering....like a 2:1 margin before you start asking questions about capabilities to do it.
/ Trailer GVRW #5
Trailer load capacity is trailer GVWR - trailer weight. A 20' 7k car trailer is around 2300 lbs. That leaves 4700. A 3515 weighs about 3000 lbs. Can't find the loader weight spec but I think it's about 1000 lbs. for my loader, the BL150 might be less. Box blades vary, my 66" BB is 550 lbs.
That puts you near the limit for that trailer.
2014 FORD F-450 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-450 XL...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2016 Ford F-150 Pickup Truck, VIN # 1FTMF1C85GKE26496 (A61165)
2016 Ford F-150...
2014 FORD F-150 (A60736)
2014 FORD F-150...
24in pin on excavator tooth bucket (A61307)
24in pin on...
