Mounted Madness said:Yoitslo2,
Your tractor alone weighs 2870 lbs.
Loader specs out to 805 lbs for the LA524.
Bucket will add to that.
You're gonna be over 4000 lbs pretty quickly.
Start adding equipment, or other equipment loaded onto the trailer it won't take long to get it over 5000 lbs.
Your average dual (3500 lb x 2) axle trailer grosses at 7000 lbs.
Take off the weight of the trailer and you've got roughly 5000 lbs capacity.
I've been looking at replacing my 3500 lb single axle since I have exceeded the maximum weight (shhhhhhhhh, don't tell compliance) on occassion.
Your minimum - 7000 lb GVW, and I'd get brakes on both axles.
If you think you'll be beyond the above weights, you might want to go and 8500 lb GVW (heavier axles) or even 10,000 GVW.
As to make, I can't recommend off hand. I suspect the majority are pretty equal, and depend on options. Check 'em out on line and then start pricing from there. That's what I've been doing.
If you want to get all the weights for your machine/implements, check the Kubota Canada Ltd.. You'll also get to see the prices we're paying up here in the north.
You go to the spec charts and it's actually more detailed then the .com site.
Good luck with the new machine.:thumbsup:
dstig1 said:Similar to my L3130, maybe a few hundred pounds lighter at most. I have a 16' 10k dual axle low boy, with brakes on both axles. It is the right weight range - I would be overweight on a 7k trailer with loader, filled tires, and something on the 3 pt. So you will probably find yourself in a similar boat weight-wise.
The length is a big problem. 16' is short for this. I can fit it on (see my avatar) but there is no room to move it around for balancing the tongue load, so I need to back it on to the trailer for best balance. I REALLY wish I had got a 20 or 22', but buying used you make compromises, and I didn't know any better at the time. If you are rarely moving it, 16' will work, but it is not optimal. If you are hauling it around a lot, I would recommend a 20 or 22' 10k dual axle, with brakes on both axles. Then make sure your hitch is rated to handle the load.
I also think this will push you into a 3/4 or 1 ton PU for safe towing. Again, if you rarely tow it, and have a 1/2 ton with a capacity near 10k, it should be fine, but if you do it a lot, or in treacherous terrain, you will want a bigger towing platform.
Trailer brands vary a lot by region. Since they are big and heavy to transport, they tend to be made regionally, and not distributed nationally so much (but some will be). Around here, Felling (MN) is big and PJ out of Texas sells a lot here too. Neither is cheap - but they seem to make quality units.
Don't go short or you will regret it!
Fxfymn said:You need to be concerned about both length and capacity as the other posters have stated, but you also need to be concerned about what you are going to use to tow it with. At a minimum you will need a 1/2 ton truck or it's SUV equivalent. Towing a trailer is about the entire package, not just the trailer.
I just purchased a 24' goose neck low boy and I love it. It tows great, has a 16,500 GVW, and over sized brakes. But if you do not have a 3/4 ton truck there is no sense talking about GN trailers for your application.
So, tell us what you are using for a tow vehicle and how much you plan on towing the package and what part of the country you are located in so responders can recommend local trailer builders.
I just bought a Kubota L3800 HST with FEL. I was wandering what would the best size trailer ? Also whats a good brand?
