Trailer for 4720 TLB
/ Trailer for 4720 TLB #1
BobQ
Conn
I am looking for a new trailer for my 4720 TLB, I am wondering what weight and length I need? I want an equipment type that goes on my hitch.
I am thinking a 10,000GVW and not too sure on length? Maybe 16 or 18 foot?
Any help would be appreciated.
Bob
/ Trailer for 4720 TLB #2
Tractor Data lists your tractor as 2580 lb plus loader and BH probably puts you in the 4500-5000 lb range. A 10K trailer is more than capable to haul it. I'd suggest an 18-20' trailer. Say 5k for the tractor plus a 2500 lb trailer puts you at 7500 lb. most 1/2T trucks can haul that load. A 3/4T would be better.
Most equipment trailers have pintle type hitch but also can have a 2 5/16" ball hitch. For securement of the tractor on trailer I suggest 4 chains and binders (one each corner) plus a chain or strap for each implement.
Equipment trailers are not as wide (width between the fenders) as a car type trailer so keep that in mind if you ever want to haul a full size vehicle such as a pickup in the future. My trailer is a tilt bed H&H trailer I bought in PA. They, of course are more expensive than non tilt but they also have equipment type trailers. Being in the northeast I found it cheaper to buy in PA. Trailers here are expensive probably because most are not made in the NE and dealers have to add shipping charges. You can also check Ebay or Craigslist for used trailers in your area.
/ Trailer for 4720 TLB #3
If tractor data has a 4720 at 2580 lbs. that's a misprint. A bare 4720 is around 4000 lbs by itself. I'm not sure how much the loader and backhoe wiegh, but I bet the total package is more like 6500-7000 lbs. So a 10,000 lb trailer should still be ok.
/ Trailer for 4720 TLB #4
My mistake. Carpenter is correct. It is listed at 3910 base weight plus loader and BH. I was looking at 3 pt. lift. Even at 3910 plus about 2200-2500 for BH and loader the 10K trailer will be what is needed.
Great, I am on the right track. I would like to get a 18 foot just so as to be a little easier to move it around my property, I am looking at a Bri-mar. Funny, I can never find anything used? or it is in bad shape and a lot of money? I have a Dodge diesel 3/4 ton for pulling with brakes, in the past I would rent or borrow a trailer when needed, neither are available any longer.
Thanks Bob
/ Trailer for 4720 TLB #6
Hi Folks,
I thought I would throw my 2 cents worth in the conversation. I have a 2810 with FEL and hauled it on an 18 foot trailer which worked fine with just the tractor and FEL. When I wanted to haul it with my 6 foot brush cutter I quickly ran out of length on the trailer. I also agree with george2615 don't forget the trailer axles must carry the weight of the tractor and equipment but also the weight of the trailer should be figured in what the axles and tires of the trailer must carry. Don't forget to also figure any ballast you may have added to the tractor for total weight.
Happy trailering!
JG
/ Trailer for 4720 TLB #7
Just for some information, most of these trailers are assembled there at the dealer. If you can afford it, have a steel floor put on the trailer, if not see if they will use pressure treated wood. Watch the tires they try to put on them, you need 10-12 ply. Last is if you can afford it, get a hydraulic tilt trailer, it will save you the constant use of the loading ramps. I don't know how much you are wanting to spend, but the tires and floor will save you a lot of money and headache in the long run. I learned the hard way, with a load of hay on my trailer and blowing out a radial tire. Now I have to replace my floor, do to boards rotting.
JHK Farms
4720i
1611 (A57192)
1611 (A57192)
2014 Bayliner 180 Boat with 2004 Venture 24ft T/A Boat Trailer (A59231)
2014 Bayliner 180...
2006 Formula 292 Boat with T/A Trailer (A59231)
2006 Formula 292...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
2013 Chevrolet Impala Sedan (A59231)
2013 Chevrolet...
2015 Komatsu HM400-3 (A60352)
2015 Komatsu...
