Trailer Brakes Locking Up- Help
   / Trailer Brakes Locking Up- Help #1
Mahindra One
London, Texas
Mahindra 4025
I have an 18' bumper pull Big Tex with brakes on rear axle. I have been having a vibration problem (separate from this post) and took the trailer to tire store this morning to have wheels balanced. Twice on short drive there the brakes locked up and I didn't even have my foot on the brake either time. These being electric brakes (the emergency stop device wasn't hooked up) can something as simple as a dirty connector cause such a condition? I really don't want to start my 130 mile journey to the ranch when having this problem, yet I don't want to disconnect the lights for travel either. Any ideas?
   / Trailer Brakes Locking Up- Help #2
Mine did the same and two wires in the connector were touching. Have to have power to lock up so it has to be at the connection with the truck. That's the way mine was but others will know far more than me.
   / Trailer Brakes Locking Up- Help #3
Yep, sounds like a short. Most likely in the female plug on the truck or the male end on the trailer
Chris
   / Trailer Brakes Locking Up- Help #4
You may have bad grease seals. If the brake linings get grease on them, contrary to what seems logical, they will lock up typically at low speeds.
Pull the drums and check.
   / Trailer Brakes Locking Up- Help #5
I would go with the short in the harness or a gain control adjustment.
   / Trailer Brakes Locking Up- Help #6
I would agree with what others have said about the short. Make you you check both sides of each part- if there is nothing in the female socket on the truck or male plug on the trailer, take each apart and check the wires on the back. Also, though unlikely, check your brake pedal switch. Most brake controllers need a signal from brake switch to actuate at all, and if somehow it is getting that signal when it shouldn't be- it would apply the brakes.
Thanks for all the good advice. I'm getting on it in the morning.
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
Pickup Truck (A59230)
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56436)
Bulk Lot of over...
Sukup 8R Subsoiler (A59814)
Sukup 8R Subsoiler...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
John Deere 204L ABSOLUTE SALE (A56436)
John Deere 204L...
