Trailer brake problem...
   / Trailer brake problem... #1
Baucom
Boiling Springs, SC
MF 2823
My 16' Hurst 7K trailer has a single brake axle. My problem is that when I plug in the lights and start to moving, as soon as the trailer moves the left wheel brake locks. The right wheel brake functions as it should. When I unplug the trailer from the truck, the left wheel brake unlocks. My first thought was the breakaway switch, but it's fine. I've pulled the drum off and looked at the brakes, and nothing appears to be obviously wrong. I've been lucky and never had any problems with electric brakes before, so I need some guidance on this one. Any suggestions? Thanks in advance.
   / Trailer brake problem... #3
Even if it were the brake away it would lock both brakes since they are wired together, not independently.
If you have torn down both assemblies and they appear fine, clean of grease, and in adjustment there are only a few possibilities. One is a bent spindle but I do not think this is likely due to you just looking things over. The more probable explanation is there is a problem with the wiring and the brake that is locking up is wired directly to the brake light circuit on the trailer giving it full 12Volts and that = lock up. It could also be just a short or it could be a total screw up in the wiring.
Like Egon said get out the meter.
Chris
   / Trailer brake problem... #4
Id jack the trailer up and verify what the wheels are doing. How do you know the right wheel is brakeing when you press on the brake?
if i had to guess the brakes are wired wrong (or your 7 way hookup is) and the right wheel isnt brakeing at all. (ie e-magnet is toast)
   / Trailer brake problem... #5
It sounds like there may be 12v power back feeding to the brake wire that supplies the wheel that has the brake problem. For example, if the ground is bad on one of the lights, the power will search for a ground and find one; if there is some wire cross connected, either intentionally or inadvertently to the brake circuit, it will activate the brake. This can be very mysterious, and cause of much blue air not suitable for children. Meanwhile the brake that appparently isn't activating, may just be so far out of adjustment(or the magnet bad) that you can't tell but it may be trying to work.
simonmeridew
   / Trailer brake problem... #6
Not much fun figuring out wiring problems, especially by yourself. Check all simple stuff first, wiring at plug, no loose wires anywhere, etc. Good Luck!
   / Trailer brake problem... #7
Also, don't forget to check your grounds. Many an electrical problem has been the result of bad grounds.
I know the RH wheel brakes when I step on the brake pedal because the rh tire locks and slides when I pull forward and step on the brake (unloaded trailer in the grass), as soon as I let off the brake the RH wheel unlocks and begins rolling again. The brakes worked fine the last time I used the trailer...this time I hooked to it and it was like the LH brake was hung.
I bought this trailer new, and all of the lights have always worked and the brakes worked fine--until now. All of the lights still work...
There are some good ideas here that I hadn't thought of that I'll have to investigate. Thanks, and keep the ideas coming...
   / Trailer brake problem... #9
Check the current (not the voltage)on wires to that brakes individually and by that I mean both wires on each brake assy.
Maybe it is a mechanical problem like magnet stuck to drum or some foreign object jamming brake band.
If you didn't know the magnet grabs the face of the drum and and the wheel movement (moving the magnet stuck to it) moves the brake band against the inside bore of the brake drum.
tom
   / Trailer brake problem... #10
I had a similar problem with a big tex car hauler with a factory 6 pin plug. i bought a 6 to 7 pin plug so I could tow it with my yukon or f250 and the brakes locked on it.. turns out there are a 'couple' wire 'standards'.. I had to swap a wire in the 6to7 adapter and then it worked fine.. apparrently power and brake power were swapped..
that or as the others said.. a short from power to brake.. however as DP said.. the brakes should be wired parallel.. so if one is getting power... the other should be as well.
I'd jack them up and spin them by hand while a couple helpers plugged in the receps and hit brakes for you.. etc. that and a vom as egon said will help.. heck.. even a test lamp..
post back
what tow vehicle?
factory trailer plug?
6 or 7 pin.. or?
soundguy
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2003 Chevrolet Silverado 3500 Crew Cab Pickup Truck with Gooseneck Hitch (A51692)
2003 Chevrolet...
2013 Volkswagen Passat Sedan (A51694)
2013 Volkswagen...
378812 (A51573)
378812 (A51573)
