Trailer Brake Controller questions
   / Trailer Brake Controller questions #1
Bob_Skurka
Super Member
The lovely Mrs_Bob went out of town and somehow a blue VW Touareg showed up in the driveway before she returned /forums/images/graemlins/grin.gif I'm still trying to figure out how that happened /forums/images/graemlins/wink.gif
Anyway, one thing I did not get arranged prior to her return was the trailer hitch set up.
There are 3 basic types of brake controllers:
Proportional
Inertia activated
Timing activated
I have 2 trucks now that have simple timing activated units but am wondering if there is any reason to step up to the more sophisticated units. I do not tow a travel trailer. I only occasionally tow a tractor, pallets of mulch or stone, etc. I've noticed on my timing activated controllers I have to adjust it for heavy loads and then when it is unloaded adjust it again for light loads, otherwise I can lock the brakes up on the trailer.
The most expensive units are only about twice the price of the cheapest units and none are overly expensive to begin with. So spending the extra $75 is not the issue. The issue is do the proportional units actually work? And do they adjust automatically like is claimed? And given that they are computer chip based controllers, then how reliable are they?
   / Trailer Brake Controller questions #2
Good post. Experiment for me and then let me know. I honestly have never checked out the differences. I have to replace the one in my truck. No matter how it is set, when I first touch the brake pedal, it initially slams on the trailer brakes. It's never fun, but at low speeds it is particularly troublesome. I just need an answer quickly. I wanted to get a new controller this weekend. You see, I'm planning on having my tractor back next week and am wanting to do some hoggin'. /forums/images/graemlins/smile.gif
   / Trailer Brake Controller questions #3
Hi, Bob. Not knowing too much about trailer brake controllers, I went with the flow and bought a Tekonsha Prodigy . It was simple to hook up and is very easy to adjust if needed. I rarely haul anything, but when I do, it works. It has a nice little cradle that you can snap it into under the dash and is removed by simply sliding it out and disconnecting one wiring harness. You could easily add a second or third wiring harness to any of your other tow vehicles and move it from vehicle to vehicle.
It seems to work well. The harder you stop, the higher the number climbs and the harder the trailer brakes come on. If you let off the brakes slightly, the unit lets the trailer brakes off slightly. I'd say(with my very limited knowledge, of course) that it works as advertised.
   / Trailer Brake Controller questions #4
I recently fried the standard timed unit I had in my 99'F250. I replaced it with one of the inertial units and was impressed with the even, more controlled stops afforded by this unit. I pull a 24' tandem 12000# cargo trailer and I'd never want one of the cheaper timed units again.
John
   / Trailer Brake Controller questions #5
I'm in the same 'boat' and found the Tekonsha Prodigy to work well.
And I am pretty sure I learned about it from TBN members. /forums/images/graemlins/wink.gif
   / Trailer Brake Controller questions #6
I went out and looked at mine, I got one of them Prodigy's like Moss.
John
Dargo . . . Take a look at the Tekonsha "Prodigy" and "Primus" controllers, or look at the Valley "Odyessy" or the Hayes "Genesis" controller. All are supposed to be proportional type inertia units as opposed to regular inertia units.
Prices are roughly $90 to $150 on line depending on model. All claim to be the best (sure they are). Not sure what the hitch shops charge for them? I just want to know what I should get bids on before I walk in and get another junky controller like I already have!!!
EDIT: WOW, you guys are quick!!! I guess while I was replying back to Dargo all you guys jumped in and gave me my answer! Thanks.
   / Trailer Brake Controller questions #8
Bob,
I have a Pendulum and an Inertia controller. Both controllers require adjustment based on a loaded/unloaded trailer. The Inertia controller has a digital readout which lets me record the settings for different loads. Both adjust brake pressure based on how fast the tow vehicle slows down... it will still apply brakes when on ice just not to their full capability.
I found (about 6mo ago) the cheapest place to buy was Southwest Wheel. I called them and asked the same question that you're wondering about. Very good to work with. Included a cable to hook into the vehicle with and had it next day.
I find that when I follow the directions that the inertia controller is easier to set correctly.
BTW. Did you find a place to get your rims chromed or new rims. I think I found a place on the west side of Cleveland.
Kurt
   / Trailer Brake Controller questions #9
What Moss said. Mine works perfectly.
The only note of caution is never to trip the breakaway switch with the trailer still plugged into the tow vehicle while the Prodigy is connected. Doing so will back feed the controller from the breakaway battery destroying the controller.
FWIW, I understand most controllers are like this.
   / Trailer Brake Controller questions #10
I've got a Tekonsha Voyager on my truck, but it needs to be replaced. The last time I used it I had to apply the trailer brakes manually. When I replace it (haven't had to tow anything recently so I'm being lazy /forums/images/graemlins/blush.gif) I'll be replacing it with a Tekonsha Prodigy.
I just ordered one for my Mom & Dad's truck from here: PPL RV . I also ordered a water heater from them at the same time and I told them I had found it elsewhere for $99 (I really did find it elsewhere for $99 but only wanted to one order and the other place didn't have the water heater) and they matched it. I believe the truck specific cable was like 10 bucks, but you could just as easly "hardwired" it in with the included harness. I haven't towed with it yet, but I really like how it set up and its ease of use.
2006 Pinguely-Haulotte Star 22J 22ft Manlift (A49346)
2006...
Ranch King Gooseneck Trailer (A50860)
Ranch King...
2015 Hooper Trailer and Foaming Unit (A50860)
2015 Hooper...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
UNUSED LANDHONOR 20,000# ELECTRIC WINCH (A50460)
UNUSED LANDHONOR...
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A48836)
2016 Hino 195h...
