Trailer boards
   / Trailer boards #1
StormVet
Long 460
Need to replace mine. 16ft low boy. 76.5 inches wide. What sizes do y’all use. 2x6,2x8,2x10’s? Which one or combo of sizes. Thanks.
   / Trailer boards #2
I used all 3 sizes before but prefer 8's or 10's . I work from the outside in and rip the center board to fit
   / Trailer boards
Do you prefer a tight fit or gaps in between.
   / Trailer boards #4
If its green/ wet wood snub them up . If they are already dry I will leave a little gap for expansion
   / Trailer boards
They will be wet. I’ll get them from Lowes. Don’t have a saw mill close to get anything other or better thickness
   / Trailer boards #6
I used all 2x6 and it got me exactly within width of framework with about 1/8 to 3/16 between each board.... Trailer had some really bad quality cedar (I think) at first and I replaces with quality Douglas Fir... Went to traditional lumber yard and they let me sort through stack to find pieces I wanted... I use a "deck" sealer on them to protect from weather and trailer is out in yard 365....
My deck is 82-1/2 wide and it took 15 2x6's and no trimming... I uses same width/pattern that I was replacing...
Used all new trailer deck screws to secure new boards....
Ironically I found a pack of deck screws at industrial hardware that has exactly 15 screws, just what I needed, amazing...
Hint: When you have all the boards off frame, mark on top of outer frame rail where cross members are under deck so when putting screws back in, crossmember is easy to locate...
Dale
   / Trailer boards #7
I used 2x6. I stacked and clamped them in the barn for several months to dry before installing. I then installed them as tight as possible. I now have small gaps, just what I was hoping for.
   / Trailer boards #8
Those screws are called trailer floor screws i believe. Try to find them at least zink coated. The black ones wont last long in PT wood. Also you dont need PT. I have a center deck on my open car trailer thats normal 2x6 thats 8 years old. I still park my mini excavator on it.
   / Trailer boards #9
I haven't had to replace my deck yet as I treated it with a 50/50 mix of linseed oil and ATF fluid. Got excellent penetration and it is not sticky or slick. Current deck is doug fir of various width. Treat it every few years using a pump sprayer.
   / Trailer boards #10
For lighter-duty trailers, 5/4" x 6" PT deck boards work well. My old "woods trailer" used to have 3/4" PT plywood. When the plywood died, I replaced it with the deck boards and like them much better. They seem to be stronger, and the gaps let water drain out, so the boards seem to be lasting longer. I spaced mine with a 16D nail to create gaps, which widened a bit at the boards dried out. It's been working out well.
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
1982 LeeBoy Motor Grader (A52748)
1982 LeeBoy Motor...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2011 Chevrolet Traverse 1LT SUV (A50324)
2011 Chevrolet...
