Trailer bearing seals
   / Trailer bearing seals #1
Diamondpilot
Super Star Member
Daleville, IN
Jinma 254/284 Ford 861 Powermaster at work
Ok, I need help.
I am currently working on a trailer projects but this one has me stumped. I have done 100's of trailer bearing/cup and seal repacks or replacements. I am working on a boat trailer with tandem 3,500# axles. I pulled all apart and washed it up in the parts washer. The seals that came out are part#168255TB
For those of you who do not know the 168 stands for 1.68" ID and the 255 stands for 2.55" OD.
I gave this part # to the Napa guy and he told me they crossed over to Timken 442251. Well before I went to put it all back together tonight at 8pm I decided to measure them with my digital calipers. The outside diameter is no problem, right at 2.55" but the ID is 1.71".
So the problems is the ID is 1.71" instead of 1.68" making it .03" too large. Do you guys think it will leak or did they cross it over wrong? I called them back and they said this is what it crosses to but my gut tells me its not going to work, just feels too loose.
Chris
   / Trailer bearing seals #2
not sure on the napa # but it's a National # 470460 and that is the size you stated..?
Thanks. That gets me closer. I will have to run back to the parts store first thing in the morning.
It was driving me nuts so I went out to the shop just a minute ago and check again and the surface where the seal seats is 1.68" and the seal with 1.71" is just a little too lose. Funny thing is I had another 3,500# axle here for another trailer I am working on for a lawn mowing company and I measured it and it is 1.71" so maybe the guy just got what he was used to getting. That axle is a Dexter. The axle's under this boat trailer are a custom made axle for Tennessee Trailer Company. It still uses the same cups and bearing as a normal 3,500# unit, just the seal is different.:confused: Makes things a Pain.
Chris
   / Trailer bearing seals #4
My guess would be if it is not an oil bath type bearing which I don't think it is it is a packed grease type for the most oart i always was told the seal was basically a dust shield so it may not make that much difference anyways?:confused:
   / Trailer bearing seals #5
In the bearing industry shielded and sealed bearings are two completely different things. The seal has to expand a little to work, if it is any amount loose it will leak grease and/or let dirt and water in..
Yea, think it will leak. It has Buddy Bearings on it so there is constant pressure so it has to be tight. I will take all the info I have and head to Napa at 9am. There is also a RV dealer down the road I can try. If not I did some searching on the net last night and these seals are what EZ Loader boat trailers used so I can get them for $2.99 each plus shipping.
Chris
   / Trailer bearing seals #7
Chris, just a thought, can you get a 'beauty ring' for that axle ?
(edit; "beauty ring" = speedy sleeve)
Not sure what a beauty ring is but here is the latest. I got on the phone for 2 hours this morning and found 4 seals about 25 miles away. So I drive there and get them but they have rubber on the outer surface instead of just metal. The rubber coating was very thin, probably .01"
Anyway I put it all together and and all was fine until I went to top off the Buddy Bearing and it blew the seal out the back side. Plus on my way home I got my first speeding ticket where the speed limit dropped from 45 to 30. He said he clocked me at 47 in the 30.
So I get to pay a $125 ticket, the first one in my 20 years of driving, and order the seals from the trailer manufacture. I talked to a guy there and they have them for $4 each so the price is not bad but will be mid week before I get them.
:mad::mad::mad:
Chris
   / Trailer bearing seals #9
The seal I.D. should be a bit smaller than the axle. Here is what I found for the specs.
Product ID: 168255TB
168255TB Grease Seal Details
I.D. Size: 1.620" -- O.D. Size: 2.560"
Found a link to a dealer who has what I need. Here is the PDF of all the seal. Will order them on Monday.
Chris
  • seals.pdf
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
18004 (A51691)
18004 (A51691)
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
(2) 1R PLANTERS (A51243)
(2) 1R PLANTERS...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
