Trailer axle knock
   / Trailer axle knock #1
wickedinhere
Kinder, Louisiana
Kubota L2800/LA463
Today i was checking my tire pressure on my trailer and i pushed on the tire with my foot and the axle made a knocking sound. I was wondering if this could be
a sign of bearing failure its about 3 years old i have never greased the bearings
but there not making any noise. I will jack it up tomorrow and see whats goin on
any suggestions?
   / Trailer axle knock #2
I'm sure that you already know that we a little more info than that
   / Trailer axle knock #4
wickedinhere said:
Tell me what you need.
Bearings somewhat snug? how much end play when you wiggle top of tire and does it make a noise when you spin wheel ? for starters , does it spin freely? without weird noises:D
I got it jacked up and checked the rear axle. Both tires spin easily with no niose
and both of them do have some play when i try to wiggle them but not very much. I was thinking maybe the axle nut is slightly loose? I not sure how often your suppose to repack the wheel bearings.
   / Trailer axle knock #6
wickedinhere said:
I got it jacked up and checked the rear axle. Both tires spin easily with no noise
The easily and no noise is a good thing :)
and the re-pack bearings will come up with a search unless someone else comes up with it, I wish you were here, we could do this in minutes
Jim
Thanks for the help, i have changed and repacked bearings before so hopefully it will go easily. I am gonna do the back axle tomorrow and if it goes pretty easy i will do the front axle also. Thanks again for the quick response and help i will update you tomorrow and let you know how it went.
   / Trailer axle knock #8
Axles are easy, no top play and good smooth sound when ya spin them, any grinding sounds are not good at all
   / Trailer axle knock #9
It's not unusual for a little play after the grease from a previous packing job has basically run out of the bearings but still there....make sense...
   / Trailer axle knock #10
I think most of the "experts" recommend annually, but I doubt that anyone actually does that. If there's very much "play" at all, I'd do it, though. It's not a difficult job; just messy.:)
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2803 (A50460)
2803 (A50460)
2019 FORD F-350 (A52472)
2019 FORD F-350...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
1269 (A50490)
1269 (A50490)
