Loader traditional VS. self leveling Loader
   / traditional VS. self leveling Loader #1
magicheater
Veteran Member
central Wisconsin
Kubota B7800, B26 TLB
I had my first taste of a self leveling loader the other day while testing some bucket mounts on a John Deere tractor. I understand the concept but was quickly dissuaded from wanting one. It actually stalled the loader in some bucket positions while lifting. Does anyone else feel this way? Unless you had forks on your loader all day long I see no real advantage to it.
   / traditional VS. self leveling Loader #2
We had the self leveling feature on our Case CX80 and took it off as we did not like it. Ours was mechanical rather than hydraulic. We did not get the feature on our M8540 as we have no real need for it. I can see where someone who does a lot of pallet work would like it though.
As always, just my opinion.
   / traditional VS. self leveling Loader #4
I've got the hydraulic self leveling loader option on my M8540 as well as the Kubota Shockless Ride (KSR) option (tractor came with both). I don't use KSR very much but I do use the self leveling feature all the time. Anytime I've got something in the bucket I just raise and lower the FEL as needed and the bucket/attachment angle remains constant relative to the ground as I raise and lower the FEL.
Even with self leveling enabled I can dig, scoop, whatever by using the normal lift/curl controls, but as soon as I stop using curl the bucket/attachment angle will stay constant relative to the ground as I raise/lower.
   / traditional VS. self leveling Loader #5
My LB-115 has it, but my M-7040 doesn't. Overall, I like it. makes the loader work a little more goof-proof, but I tend to use my loader control to level the bucket as I raise it because I owned a lot of machines without self-leveling feature.
If I had my choice, I'd rather have it. I'd love to have the ride control accumulator as well, but anyone can get by without them.
Piller: remove your KSR option and sell it to me. :)
   / traditional VS. self leveling Loader #6
I do quite a bit of pallet fork work with my new 4720 Deere. I have the 400CX loader which is mech self leveling. I love it!!
   / traditional VS. self leveling Loader #7
If you move pallets a lot, a great thing to have.
When I first got my 7520 tractor, I was uncertain whether I liked it or not. My brother absolutely hates it. But the more that I used the loader the lazier I got and the more I liked it. Didn't actually realize how much I like it until I bought my little 3215 that does not have it. I now feel that I would not have a new tractor without it as long as it was an option.
Overall self leveling is just a convenience and someone that is not use to that convenience can feel that it is just an annoyance.
   / traditional VS. self leveling Loader #8
I often think I would LIKE to have it, sometimes I would like it a LOT for bucket work.
What I think I would like even MORE would be a good PRECISE and ACCURATE bucket roll/dump POSITION (wrt tractor's "level") control.
Like; zero is parallel to the ground (as determined by the tractor's wheels).
Divisions every 2 degrees or so roll/dump from there - and REPEATABLE !!!
   / traditional VS. self leveling Loader #9
According to Deere, the self-levelling 400CX has 25%-30% more lifting capacity than the 400X, which is a good reason alone to get it IMO. Bigger cylinders in that case, I guess. I don't have anything to compare it to, but it sure is nice.
   / traditional VS. self leveling Loader #10
So how would the indicator work? Every height the loader is at, the indicator would have to be different. I guess that an electronic system could be set up, but I don't see how a mechanical system would work. :confused2:
2019 Ford Fusion Sedan (A46684)
2019 Ford Fusion...
2021 Doosan DX350LC-5 Hydraulic Excavator (A46683)
2021 Doosan...
2014 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A46684)
2014 Chevrolet...
2008 Hyundai Tiburon Coupe (A48082)
2008 Hyundai...
John Deere Mini Drill (A49251)
John Deere Mini...
Massey Ferguson 275 2WD Tractor (A49251)
Massey Ferguson...
