Tractor work lights.
   / Tractor work lights. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I finally got around to mounting a pair of cheap lights to my roll bar. My Kubota L4400 comes prewired for work lights on the fender so I just tied into those. They work great but with two problems. 1. They come on when the ignition is turned on and are not controlled by the headlight switch. 2. I had to mount them below the roll bar and not on top because on top they would get knocked off immediately.:laughing: Because of this positioning you cannot see anything behind you when they are on. I'll experiment with positioning them to the sides of the roll bar since my homemade brackets will fit anywhere on the roller.
But, the bottom line is that I need a switch.
Any recommendations for a simple to wire, cheap, out door switch?
   / Tractor work lights. #2
   / Tractor work lights. #3
Food for thought. You could put a relay in that is activated by the headlight switch. Use the connector you are now for the load side of the circuit to the lights and a wire from the headlight circuit to the low amp side(signal side) of the relay. Depending on how the harnesses are on the machine it could be quick and simple, or more of a pain than adding a switch. Again, just food for thought.
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
2022 TAKEUCHI TB2150 EXCAVATOR (A51242)
2022 TAKEUCHI...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
1999 John Deere 7810 4wd Tractor (A52128)
1999 John Deere...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
Portable Cattle Loading Shute (A50515)
Portable Cattle...
