tractor won't stay running
   / tractor won't stay running #1
knk810
arlington hgts,ill
cub cadet 125
have a cub cadet 125 1970, rewired voltage regulator and have a brand new battery, starts right up, won't stay running...I am thinking its the generator...any ideas
   / tractor won't stay running #2
A new (charged) battery should run the engine a looong time!
I'm more inclined to think clogged fuel system.
Also check the vent on the fuel cap.
Could also be cr*ppy modern gas clogging up the carb.
tank has an old screw top with 3 holes, I will drain the tank and blow out the fuel line...it ran just fine last year and then it just crapped out while mulching leaves
   / tractor won't stay running #4
also check the fuel tank cap vent is not plugged up....
Ok , Thanks for all the help, tractor is running but my new issue is it is back firing and when I throttle up, the rpms are alot faster than before but when I engage my mower deck, 42 inch, rpms decrease a little.. any suggestions?
Brent 776 Grain Cart (A50514)
Brent 776 Grain...
Ford 8N Tractor w/3pt. Buck Saw (AS IS) (A50774)
Ford 8N Tractor...
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
Electric Mobility Scooter (A51694)
Electric Mobility...
UNUSED MOWERKING QUICK ATTACH 72" HYD BRUSH CUTTER (A51244)
UNUSED MOWERKING...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
