tractor wont start
   / tractor wont start #1
glenkoto
Monroe
kubota b21
hi everyone
My 1997 Kubota B21 wont start when i turn the key. If i run a wire from the battery to the low voltage side (BW) of the solenoid it starts just fine. Does anyone have a wiring diagram of this model? i have swiches at the PTO, clutch pedal,and transmissio shifter. Are there any others? My plan is to jump each switch til I get juice at the low voltage terminal of the solenoid. Is there a particular order to these switches? The Clutch connector has BW and BY on one side and BW and BW on the other. Both PTO and Trany connectors are BY and BB on one side and BW and BW on the other. Your help is appreciated. Gary
   / tractor wont start #2
Usually there is a seat on the seat to detect an operator is present.
I am not certain on your particular model but often each switch sends a signal individually to a controller which then send power to the starter.
This is because not all switches do the same result on the tractor starting or running. For example, the pto switch may only affect and alarm if you are n ot in the seat and the pto is engaged. The pto switch may prevent starting if it is engaged.
The orange tractor forum is dedicated to your brand of tractor. Look for posts by "Wolfman," he is the real expert and often will give you a link to WSM's which have the trouble shooting guides and wiring diagrams. OrangeTractorTalks | Kubota Tractor Tips, Classifieds, Specifications and Discussion
Dave M7040
   / tractor wont start #3
I have the same problem. Been dealing cheating it for a year now. There are safeties (three) that need to engage (plunger type) that maybe bad (I think mine are) in fact I am researching a thread I started long ago that has the solution. There is one on your clutch pivot, seat and I believe your 3 point.
I believe I was told (That's what I am looking for) that you can test the safeties with a OHM meter for resistance. Apparently they build up corrosion inside and fail. I have been jumping mine for way too long and I have committed to fixing it now!
There are plenty of diagrams on the Kubota web site.
2021 BOBCAT T870 SKID STEER (A52705)
2021 BOBCAT T870...
2015 FORD F550 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XL...
JOHN DEERE 2750 TRACTOR (A54756)
JOHN DEERE 2750...
JOHN DEERE 333G SKID STEER (A52705)
JOHN DEERE 333G...
25in x 10in Kubota RTV-X1140 Tires (A52377)
25in x 10in Kubota...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
