Tractor won't go into gear
   / Tractor won't go into gear #1
Troyboy450
Tn70d
Need help with new Holland tn70d, won't go into gear
   / Tractor won't go into gear #2
We need more info on what happened.
IF it's a gear drive my experience with my M4700 might be pertinent.
This has happened 2 or 3 times over 10 years, but only about 100 operating hours or less (it's approaching 1500 hrs).
On my M4700 it wouldn't shift from 3rd to 1st/2nd.
The first time(s)
I went underneath and traced the levers and found they were binding a bit.
Generous application of fluid film freed them up. And light tapping with a suitable tool.
The last time, a few months ago I found a twig had managed to wedge itself in the way.
So check out the lever path.
   / Tractor won't go into gear #3
Twice I have had this issue - if your problem is the same it is an easy fix: The range shifter appeared to be in a correct place but the tractor would not move. The issue was that the range lever was not quite engaged, i.e., not in the slot. A tap or two with a small 2 x 2, or a long screwdriver to ease it into the slot, was all it took. You may have to remove the covering - I am not familiar with your tractor. Removing any cover may be a good idea anyway so you can see precisely what is happening.
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
2018 Ford Explorer SUV (A55758)
2018 Ford Explorer...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A54756)
(INOP) 2016...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2015 Dodge Grand Caravan (A53424)
2015 Dodge Grand...
