Tractor Winch Weight
   / Tractor Winch Weight #1
Sawmillboy
Kubota MX5800
I know there are lots of threads on these but I was looking for input on the weight of the units.
I’m looking at getting a 4 ton winch, debating between an Igland, KRPAN, and a Fransgard.
They are all priced similarly and the Igland is 573lbs, KRPAN 847lbs, and Fransgard 657lbs.
I’m going to be cutting a little bit of pine sawlogs around our property, biggest ones are around 35” and it is pretty hilly around us.
I like the KRPAN the best but is the extra weight of these going to affect me driving the logs out of the woods significantly? I have a kubota mx5800 and the 3pt is rated to lift 2,310lbs
   / Tractor Winch Weight #2
You can only lift so much (2310 lbs, it appears...) so every pound in the implement is one pound you won't be able to lift in logs. Flip side is the heavier the unit, the more sturdy-built it likely is. But skidding logs only requires you to get the butt off the ground, not the whole log. With logs that large odds are you are going to have only one hooked up, or two smaller ones, perhaps. You can pull a surprising amount this way....carefully.
Bigger concern is if you have a lot of hills, will any of that be side pulls? That is asking to roll the tractor and handling those areas gets more difficult and time consuming. Better practice there is to drop the log, move tractor forward and then winch it to the tractor again on flat ground, rather than skidding it out attached to the tractor on a side hill. Set those rear tires as wide as you can!
  • Good Post
Reactions: JJT
   / Tractor Winch Weight #3
You need to pick up half the log's weight to drag it with the winch. You can calculate log weight here: Timber and Lumber Calculators at WOODWEB
You could use the winch to pull logs to a landing and then drag them off with a log arch. But that's an extra piece of equipment. Some winches come with fittings for trailer hitches.
I think the Krpan has a longer cable than the Igland. I'm not sure about the Fransgard. If it's steep with limited access or you need to redirect pulls with snatch blocks the extra cable may come in handy.
Thanks guys, that lumber weight calculator is a cool tool. I’m certainly aware of the side pull danger and aware of dragging the logs out on a hillside, I will winch it extra times if I have to rather than risk it. The Krpan also has 230’ of wire compared to 160 ish of the Igland/fransgard.
According to the weight calculator, it says a 16’ 35” white pine is about 3,800lbs. Any idea if the three point would be able to pick this up? I guess a couple hundred pound difference between the other winches isn’t going to make or break the capacity when I start getting into those large logs.
   / Tractor Winch Weight #5
If you're picking up one end, then that will be about half if that, or about 1900 lbs plus the weight of the winch.
So you're rapidly approaching your 3pt capacity.
What you need to figure out is whether the 3pt capacity could be increased with having a front end loader, or front end ballast. Kubota might have the answer.
Dragging a 3,800 lb log might stress your winch. The winch manufacturer might be able to help you whether an 8K winch is adequate.
   / Tractor Winch Weight #6
I've had electric winches on six vehicles I've owned over 55 years. The one absolute truth - the closer you get to the max capacity of a winch - the quicker bad things will happen. And - the more often they will happen. And this will apply to most all machinery.
   / Tractor Winch Weight #7
Probably true in general, but you're probably better off with an 8,000 lb Warn winch than a 12,000 lb Badlands Harbor Freight winch.
Find yourself a vintage 50+ year old 1 HP grinder and a new 1 HP Harbor Freight grinder, and there will be no comparison between the two.
Taking the tractor right up to 100% of its rated capacity, and then it all depends on manufacturing tolerances.
   / Tractor Winch Weight #8
I have an Igland 3501, (7700# capacity), and have no issues with 30"+ hardwood logs. I also have a 2300# 3 pt hitch lift capacity.
Appreciate the input, I emailed kubota about a front end loader increasing the capacity but haven’t heard back. I would hope that an 8k winch would be more than capable to pull out a 3,800lb log but I’ll definitely ask! Anyone familiar with the clutches? Looks like the Krpan and Fransgard have a better clutch than the Igland.
Cool good to know! I think im going with the Krpan because of the longer cable but I’ve heard good things about all of them
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A52128)
2019 Ford F550 4x4...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
