Tractor Weight
   / Tractor Weight #1
rockman20
Does anyone know approximately how much a International cab weighs? We need to haul a International 966 with a cab. The cab has full glass on it. I know the tractor comes in at 11,116 pounds. I am just curious on the weight of the cab. We will be using a 40 foot gooseneck with three 7,500 pound axles under it. I would feel comfortable with the tractor alone, but it comes with a snowblower as well which should come in around 1,300 pounds. So tractor and blower are around 12,400 pounds. Just curious if anyone has an idea what the cab would weigh in at.
Thanks!
   / Tractor Weight
It just has heat, no air.
   / Tractor Weight #4
Why are you wanting to know?
If you are concerned about the weight for towing I would say that it would be fairly minuscule compared to the rest of the rig.
   / Tractor Weight
Just like to know how much weight we have when we load. Especially considering we will be crossing state lines and are in an area where sugar beets are in harvest which means extra troops on the roads watching for over weight vehicles.
   / Tractor Weight #6
The heaviest one was 13500 (from tractordata) and I do not think they made a 4wd version?
Tires are loaded too I assume? A good 1k+ there. Any extra weights on the front?
You should still be fine with a 22k trailer.
   / Tractor Weight #7
Thanks!
I'll bet you're at around 13,500 total on the tractor and 6500 on the trailer, for 20k total weight. The weight international lists for the tractor does not include the fluids either - nearly 100 gallons of fluids if full.
2009 Ford F-350 4x4 Flatbed Truck (A51691)
2009 Ford F-350...
1994 Trailmobile 51 ft. Dry Van Trailer (A53117)
1994 Trailmobile...
2019 Bobcat T590 (A50123)
2019 Bobcat T590...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
Pallet of Misc Fabrication Steel (A52384)
Pallet of Misc...
