Tractor Washing
   / Tractor Washing #1
SouthernX
I just got my first tractor a little while back and it's looking like it's time to clean it up a little. I looked in my owners manual but didn't find anything about appearance care. So, do you having any advice when it comes to washing and cleaning up your tractor? I figure for starters it might be a good idea to take a sheet of plastic and cover the (cold) engine with it before washing it.
   / Tractor Washing #2
Does your tractor not have a hood over the engine? I just use car care products for cleaning.
   / Tractor Washing #3
I washed the engine as well as the rest of the tractor. Of course I wash the engine in my car and pickup, too. I tried to avoid spraying water directly on the instrument panel or into the air intake on the engine. And after washing, I usually blew off any surplus water with the air hose, then run the engine (whether tractor, car, pickup, or lawn mower) long enough to get up to normal temperature and evaporate any remaining moisture.
   / Tractor Washing #4
I rinse my tractor off pretty frequently. Dirt and dust hold moisture against the paint and metal. I've had my tractor for three years. I've washed it twice with soap and water. Just do the same thing you would with a car. I've waxed the painted surfaces once. Just use a basic automotive wax. I know a lot of hard core tractor folks think that is funny, but there are several things to consider. First, my tractor basically lives outdoors, just recently built a shed for it, but even that has open sides. A wax job once every few years will probably go a long way to protect the painted surfaces. Second, good paint helps resale. If you doubt that, look at used tractor classifieds. Many if not most will comment on the paint. Buyers care.....even if they say they don't. Third, I find that in general I take care of something a lot better if I feel good about how it looks. Maybe that's just me, maybe its human nature.
   / Tractor Washing #5
I wash my tractors just like a car.. spray out the rad fins.. blow any debri of fthe top o fthe engine.. try not to wet down breathers and vents and instruments.. and the charge system..
soundguy
   / Tractor Washing #6
Diesels don't have distributors and plugs, so they are much less sensitive to water than a gas engine. I pressure wash mine when it's caked with mud. But, I use a normal hose for the engine and especially the radiator.
If it's just dusty or full of mowing debris, a compressed air blow out is all it takes.
jb
   / Tractor Washing #7
I spray the engine and any greasy places down with SimpleGreen, let it set for 10 min. and then hose it off. Then I give hood, fenders, wheels and the rest a good washing with TurtleWax car was. Then I hit the dashboard and rearmounted fueltank with Armorall and it looks so good I could drive it to church on Sunday!
   / Tractor Washing #8
When you go by a dealers lot, how many tractors are sitting inside of garages, and how many are exposed to the elements - before you buy them. Me, I have hosed my tractor off twice since new. Both times it was due to the excessive amounts of mud on it. Other than that, it isn't a show piece.
I would do what everyone else is telling you, use car care products. I wouldn't worry about the water, unless it is under pressure. Then I would be careful where I sprayed it. I would not wash it off anywhere near my yard or driveway though, as the big globs of mud and dirt will be there afterwards.
I would also lift my bucket an tip the water out afterwards, then let it air dry before putting it away.
   / Tractor Washing #9
I hit mine with the leaf blower every time I finished mowing before I put it away. I'm amazed how much dust and dirt flies off and how much better it looks just doing this and I'm not worried about the grass on the deck and around hot spots. About once an month or so I spray off and wipe down with a towel and still looks like new.
   / Tractor Washing #10
I clean my tractor most of the time with the air nozzle using air compressor pressure. I usually wash it once or twice/year with water and maybe give it a wax job. Last time I changed the engine oil, I washed the engine just like I do the engines on my cars and pickup: with spray nozzle on 45 psi well water, using Purple Power or Simple Green to presoak any especially oily or greasy areas. In the old days before Simple Green and such, I'd water wet and then sprinkle Tide powder over the oily/greasy areas and let it sit. Then washed it off with a water nozzle.
NEVER use a power washer, as the gaskets and seals on the tractor aren't good to take that kind of pressure.
The only trouble I've ever had was a loosey goosey distributor cap on one car I owned. On it, I'd have to remove the cap and dab out the water. Also, on my Ford Ranger, I had a couple spark plugs rust out because I didn't blow out the water from the spark plug wells. The Toyota I have now has even deeper spark plug wells, but they are well sealed with caps around the wires entering the wells.
Ralph
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
Unused Delta Crash...
2003 Paris Utility Trailer (A52377)
2003 Paris Utility...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
