Tractor tire sizes
   / Tractor tire sizes #1
kabrams
Frankfort, Ky
Ford 4630
I have a 16.9 - 30 tire that needs an inner tube. Will a 16.9/18.4R-38 16.9-38 18.4-38 TR218 tube fit in this tire?
   / Tractor tire sizes #2
No. You need a 16.9/18.4-30 tube.
   / Tractor tire sizes #3
+1. I can agree with some moving about on cross section diameter, but not on rim diameter. Course if you are in a tight and can stand a failure down the road, it will just have a lot of creases in it which might or might not cause a crack. Nothing ventured nothing gained or lost......if you can stand losing.
   / Tractor tire sizes #4
Always stay with same rim diameter. If I was going to switch a size in regards to cross section diameter, I'd go smaller rather than larger. Creases in the tube from being too large will come back to bite you.
   / Tractor tire sizes #5
The larger tubes are made to handle two different widths. 16.9/18.4 , 11.2/12.4 13.6/14.9 ect. I would not recommend using a 13.6/14.9 tube in a 16.9 or 18.4 tire.
2015 FORD F-350 (A45333)
2015 FORD F-350...
2012 FREIGHTLINER CORONADO 122 SD (A45333)
2012 FREIGHTLINER...
2012 Volkswagen Tiguan SUV (A42744)
2012 Volkswagen...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A43004)
2018 FREIGHTLINER...
1999 Ford Econoline Van, VIN # 1FTRE14W0XHB81450 (A44391)
1999 Ford...
More info coming soon! (A44572)
More info coming...
