Tractor supply seat?
   / Tractor supply seat? #1
Jeff Lary
Hartland Maine
Kubota L2950
My seat is the orig Vinal on my 95 L2950 and shes pretty worn out.What are the chances that if I unbolt the seat (not the sliding sub frame partunderneath it) and measured the seat bolt holes that I could go to ts and find a seat that would use the same bolt pattern? Has anyone ever tried this ? I am just looking for an easy hassel free seat replacement .Does anyone have a thoughts? Thanks
   / Tractor supply seat? #2
I have seen a seat at Tractor Supply that is for a Kubota, so it is possible they have one in stock. I think the bolt patterns for seats may be brand specific.
wel I have not taken the bolt pattern measurements yet but I will have to do that, then go look I guess.
   / Tractor supply seat? #4
Most all the seats have several holes or bolt patterns for mounting. I got one of those high back ones with armrests for my JD when I had it. You may have to drill different holes at worst. Good luck.
Shortkid
I guess I would have to take the seat off first but when you say" may have to drill some holes " you lost me. Like I said without looking close it seems to me that the seat has threaded hole's in it that the bolts go into or am I wrong about that.
OHHHH did you mean drill the sub seat assembly the part that the seat bolts to ??? The sliding assembly? I can see how that could be done .Some time's I have to say things out loud ,or on paper to see that I may have been confused . Let me know if that is what you ment.Thanks
2019 Caterpillar 299D2 High Flow XPS 95 HP Track Loader Skid Steer (A50322)
2019 Caterpillar...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
48" Pallet Forks  (A52384)
48" Pallet Forks...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
John Deere Hayrack (A50515)
John Deere Hayrack...
2018 Dodge Charger (A50515)
2018 Dodge Charger...
