fishman
Veteran Member
I've read through most of the threads on the TSC digger but still am unsure if it will meet my needs. I'm not going to be using it a lot, but I can see myself drilling at least 100 holes over the next 3 years. I need a 12" auger because some of those holes are going to be for a pole barn, and others will be for corner posts, etc.
Now, I've got a lot of ground where there is firmly packed gravel with a very few cobble-sized pieces (3"-6"). Only a little bit of the gravel is hard stuff, and the rest is fairly fragile limestone. Some of my ground is soil so that shouldn't be a problem. About 2/3 has layers of fairly fragile limestone bedrock just under the soil that ranges from 8" to 2' in depth and overlays the gravel layer. I don't necessarilly have to drill holes in the limestone, but it would be nice to have that capability.
I just can't justify spending $875 for a digger.
So I ask, what are the capabilities of a light-duty auger, most specifically the TSC model? What can I expect from it? I don't have a problem with working a little slower than a "professional" grade digger would allow, nor do I have a problem with buying plenty of extra teeth if needed (are they needed?). /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
