Tractor Supply Post Hole Digger - Upgrades and Thoughts after 5 years of ownership
   / Tractor Supply Post Hole Digger - Upgrades and Thoughts after 5 years of ownership #1
goddom
Bronze Member
Flat Rock, MI
LS G3038H
Hey everyone. So I have had my TSC post hole digger for probably 5 years or so and sunk quiet a few posts with it. After so many years and posts a few issues have cropped up. Nothing to serious. One is that the input shaft seal leaks on the gear box. Not the end of the world, I just top it off before I use it. Second thing is the ears that support the boom have opened up over time. I finally got around to bending them back into place and then welding some gussets to keep it from happening. This makes the thing so much more stable left to right. I even welded a washer in to help tighten them up a bit more. If you buy one of these I would suggest welding on these gussets on right away.
My father-in-law got the same auger and he leaves his on the the tractor most of the time and the ball thing at the end of the boom that attaches to the top most 3-point hitch started to wear out from the thing getting jostle around on the back of the tractor all the time. He is having to weld in a replacement ball. For that I would suggest taking the auger off if not in use.
Here is a video I shot of the gusset weld repair if you are interested:
Welding Project - Fixing Tractor Supply Post Hole Digger - YouTube
   / Tractor Supply Post Hole Digger - Upgrades and Thoughts after 5 years of ownership #2
Good job on the repair and the video.
   / Tractor Supply Post Hole Digger - Upgrades and Thoughts after 5 years of ownership #3
Straight forward repair, thanks for the video. Thumbs up.
   / Tractor Supply Post Hole Digger - Upgrades and Thoughts after 5 years of ownership #4
Great little upgrade... Going to put it on my to do list...
Glad you guys are finding it helpful! Thanks!
   / Tractor Supply Post Hole Digger - Upgrades and Thoughts after 5 years of ownership #6
I have the same PHD. It flops around a lot also. Thanks for the video.
I tried it out and HUGE improvement. I shot some video I will upload at some point.
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2011 GMC SIERRA 2500 (A52472)
2011 GMC SIERRA...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
