Tractor stops pulling in forward or reverse
   / Tractor stops pulling in forward or reverse #1
David Hayes
Martinsville, Virginia
new holland TC55DA ehss
I have a new holland TC55DA, EHSS. Purchased this machine new. When I first start the tractor it will move OK. Then it quits pulling, doesn't matter if in forward or reverse. I can cut it off and restart it, pulls fine for a few feet, then quits pulling. After this happens several times it starts pulling again for a short time and does same thing, quits pulling. I have changed filters and hydraulic oil. No help there. This is first problem that I have had with this machine. Engine runs great. Can someone give me an idea what the problem is? I have checked the dump valve, it is working OK.
Thanks for any help.
   / Tractor stops pulling in forward or reverse #2
How is your rear tire pressure.? Several people have noted the rims turning but not the tires under load. Low pressure and cold weather. Just an idea.. You would never know, as you are sitting on the tractor, have someone stand on the ground, and observe the wheel/tires.
Thanks for your advice. Tire pressure is OK
   / Tractor stops pulling in forward or reverse #5
OK.. let us know what it was when you get it figured out, I was hoping it would be something simple.
I will surely post here when I find out the problem. I think it is the EHSS controller Module. When the problem happens, I can turn switch off and restart the machine, the machine will move fine for a few minutes then stop pulling again. I think when I shut off the switch that resets the controller module. I have checked all wiring, nothing is loose.
   / Tractor stops pulling in forward or reverse #7
This is one of those times when you are going to have to bite the bullet and call a service tech. With the electronics it can be something really simple like a sensor or it could be the module. With out the right diagnostic equipment you wont figure it out without spending a lot of $$$ on parts you don't need.
Bill
After many hours and a lot of money spent. Found the problem. It was the HSS Controller Module. The tractor mechanic spent several hours and could not diagnose the problem. Thanks for your suggestions.
2024 Scag V Ride XL (A51573)
2024 Scag V Ride...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2018 INTERNATIONAL LT625 SLEEPER TRUCK (INOPERABLE) (A52472)
2018 INTERNATIONAL...
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
2006 FORD F-250 (A52472)
2006 FORD F-250...
