Tractor Smoking
   / Tractor Smoking #1
rims421
Eastern CT
new holland tc- 35
I have a Cub Cadet 7275 it runs fine has plenty of power and does not use any oil between oil changes.
The problem I have is the tractor smokes more than any other deisel tractor that i have owned. It is made worse I think by having the exhaust pipe located below the engine compartment instead of overhead like most units. Is this anything I should be concerned about? It has been a pain recently while I have been using the tractor for skidding trees.
Every time I jump off the machine to chain up a log I have to inhale more exhaust than I would like. Anyone have any suggestions regarding possible solutions to this situation.
   / Tractor Smoking #2
Smoke color? Check air filter. Check injectors for dribbling.
   / Tractor Smoking #3
Slobber any?
Soundguy
   / Tractor Smoking
The color of the smoke is blue / white. I will check the air filter.
What do you mean by the injectors dribbling?
   / Tractor Smoking #5
"Every time I jump off the machine to chain up a log I have to inhale more exhaust than I would like."
Sure...reroute the exhaust overhead. Then you won't have to breathe all those fumes when you jump off the machine...Only while driving it! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Tractor Smoking #6
Check around the injectors for any leaking fuel, if the nozzles are not seated in the head properly, you could have a compression leak as well as a fuel leak. Torque down the injector nozzles into the head to seat them properly if you see any leaks.
   / Tractor Smoking #7
Pull them and look for wet nozzles. Dribbling will cause excesss fuel and smoke.
   / Tractor Smoking #8
rims,
I've got a 7264 with no smoke at all only at start up , usually one large black "puff'.
You may have an injector problem as others have said or maybe a little water.
GrayBeard
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
23018 (A53424)
23018 (A53424)
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A53473)
2022 JCB 3TS-8T...
2121 (A51244)
2121 (A51244)
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
2012 PETERBILT 365 (A53843)
2012 PETERBILT 365...
