Tractor Sizing tractor size
   / tractor size #1
jpm
Platinum Member
Redbud.southern vt
4110 mahindra
i'm thinking of trading up my tractor to a larger class from a 28 hp to a 35or 40 hp . how much of a differance in traction and stabity does the extra couple of inchs in lenth and with add?
   / tractor size #2
This is a generalization, but the stability of the bare tractors are probably not all that different. The larger rig gains an advantage when you start adding attachments or payload. For example, you may be able to pick up the same 500 lb. stump in your loader with both a big and a small tractor, but the bigger one will be more stable in actually carrying it someplace.
All other things being equal (tires, 2WD vs. 4WD, etc.) a 35-40 hp tractor weighs considerably more and will have an advantage in traction. It will pull or push objects a smaller tractor can't budge. But, being heavier, it's also not as good for mowing your front lawn!
Of course, knowing the limits of the equipment is equally important whether it's a large tractor or a smaller one.
Just as a suggestion, maybe you can itemize the specific tasks you need to do, or the ones that your current tractor doesn't measure up to, and use that list as a guide for determining what size range you need to look at.
2003 Ford F-450 Knapheide Enclosed Service Truck (A48081)
2003 Ford F-450...
2025 K4525 UNUSED Double Garage Steel Barn (A50860)
2025 K4525 UNUSED...
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
1271 (A50490)
1271 (A50490)
2022 Club Car...
2013 Chevy Silverado 2500 HD (A51039)
2013 Chevy...
