Tractor Size for Snow Removal and other Chores
   / Tractor Size for Snow Removal and other Chores #1
symphony
Ontario
None
I know winter is almost over for most of us but I'm considering a tractor to do various chores around my weekend retreat. One of the most important functions it will be used for is snow removal. FEL and other implements will be purchased for other chores around the property. Our unpaved road, which is not plowed by the municipality, is almost a 3/4 of a mile long and is very steep in some spots. We get quite a bit of snow and can easily get 4+ feet of accumulation by the time winter is over. I've looked at various manufacturers (Kioti, Kubota, New Holland etc...) and they all seem to offer the same features like climate controlled cabs, rear and mid PTO, front/rear hydraulics, HST. I've considered a more conventional set-up with a snow blade on 4x4 truck but I don't think it'll work since as the snow accumulates during the season, there won't be places to push it off to since the road is narrow and lined with trees. Blowing the snow seems to be the best option but it would be considerably slower than pushing it.
My configuration would include a front mount 72 inch (or larger) snow blower (single or two-stage) running off the mid-PTO. The tractor will be chained to get me safely up and down the steep grades. What are your thoughts on the size (HP) of the tractor I should be looking at? Budget is obviously a consideration so although I'd like to dream of owning a 150+ HP monster, it's financially not in the cards. I would like to purchase the smallest climate controlled tractor that will get the job done efficiently. I'm thinking that something in the 40-60 HP range should be fine?
What say ye my snow veterans?
   / Tractor Size for Snow Removal and other Chores #2
Sounds like you've done your research! I agree that 40-60hp is your best bet for a HP range. I believe that all the manufacturers you have listed can provide you with a factory front-mounted blower. I recently looked into Kioti- check out the DK40/DK50- I think they look like a great deal with all the features you want. A few neighbors have Kubota's that they love as well- mostly smaller versions with 60" blowers. One pass up the driveway, and one down and they're done.
Good luck!
   / Tractor Size for Snow Removal and other Chores #3
Welcome aboard.
Sounds like you could pretty easily do the job with a smaller tractor if snow blowing is your main task. Personally, if I was gonna spend the 25-35k for a cabbed B series Kubota, I would spend the additional $ to jump to the next size up like you're looking at, but snow isn't my only use. If you have other uses in addition to snow, like mowing, firewood, etc, and the $ is available, the size you are looking at is a very capable range.
If I was doing a lot of snow blowing, I'd definitely want a hydro tranny. Good luck in your pursuit, tons of good pitons out there. Let us know which one you pick.
   / Tractor Size for Snow Removal and other Chores #4
Been doing commercial snow removal for 20+ years. I only do parking lots now, no more driveways other than my own. With that being said my DK50 has exceeded my expectations as a snow removal unit. I have a 8' pushbox and a 7' double auger blower on the back. Works great for removing snowbanks from plow trucks. Anyway if I was doing just driveways a front mounted pto or hydraulic blower would be my first choice. Do you need that big of a unit for a driveway? No but it sure is fun! A hydrostat is a must have for a blower, makes things so much nicer for controlling speed and just about everything else. 2 stage for the blower and get a set of chains like you said. 1 rule of thumb for blowing snow, horsepower is king. CJ
   / Tractor Size for Snow Removal and other Chores #5
Don't forget to check out your local LS tractor dealer. Their prices are very competitive. The XR4046HC has 46 HP, a cab and Hydrostatic trans. Loader has 2500 Lb. lift, 3 pt has 2756 lb lift. I think it would be ideal for your needs. The 50 and up HP cab models (U5020C,XU5055C, P7030C) have a cab but don't have HST but do have everything else you need. I have a smaller version XR3037HC (36.5HP) with loader and plow snow with a 7'6" snow pusher blade. I live in the snow belt of upstate NY just S.E of Lake Ontario. Kubota, Deere, Kioti, Massey, Mahindra, Case, and others also have models in the HP range you are looking for. Whatever you get I'd recommend buying a set of chains and buying or making a rear ballast weight. You can get a snow blower for any brand you choose.
   / Tractor Size for Snow Removal and other Chores #6
What else will you do with your tractor? Might consider the heaviest lift you'll ever need from the FEL, and factor that in to the size of the machine. In the summer I get almost as much use out of my pallet forks as from the bucket.
   / Tractor Size for Snow Removal and other Chores #8
3/4 mile and steep? most brands mentioned, hydrostatic, cabbed, chains and or ballasted tires.
Probably 30 hp would be adequate.
2 stage blower a must and be sure that blower is wider than tire track by about 6".
While front mount is very nice it is also close to 2X a rear mount.
I for one would opt to have a FEL and rear mount for greater year round usage for not much more $$ as you will soon find a whole lot more usage than you imagined.
Sitting 'side saddle' while blowing is not all that difficult to master, besides you could consider installing a camera. (I plan on that for next winter)
Perhaps more important is the dealer and his service than the brand as all brands you mention are good.
As to blowers, most are made in Quebec and very rugged. You want a 4 blade fan with chain drive auger. Puma, Pronovost are 2 good makes.
Any with the center gear box are generally light duty and a few even use walk behind gear boxes like found on Aerien and Cdn tire units.
ps; I am in Quebec with good snowfalls and make do very well with 60" rear blower on a 20hp gear box tractor. It is all in the techniques you soon learn. I added a frt plow for the lighter snow events simply to speed things up. My drive is just a bit less than yours.
   / Tractor Size for Snow Removal and other Chores #9
Well, here's my 2cent's...
40 horse would be the ideal power (in that range) you may need that horsepower later
for other attachments you'll be buying.
A heated cab, is a must....
Have the tires "loaded....
I would recommend Agriculture R1 tires (loaded), no chains would be needed in this case,
with this setup, you'll have no problems going up and down those hills "if",
you have a rear blower for added weight. (72" is what i'd get)
You should also consider a "rear pull type" blower, with that 3/4 mile driveway,
you'll enjoy it and you could also install a "truck like plow" within your front bucket,
or as a QA, leaving you with the use of the loader and or plow when needed.
HST or GST trans, your choice.
Good luck on your purchase, :)
   / Tractor Size for Snow Removal and other Chores #10
40HP is not nearly enough power with a hydrostat setup.
60HP minimum unless you want to blow snow all day long. Takes power to git er done in short order. I bought a 40hp Kubota that I wouldn't wish on my worst enemy. Don't make the same mistake I did; TRY the blower and tractor setup BEFORE you plunk your money down! Also some blowers blow snow better than others.
Fred
2006 Mercedes R-Class R-500 | Used Vehicle for Parts or Restoration (A44789)
2006 Mercedes...
45022 (A44572)
45022 (A44572)
2014 CS&P  BLENDER (A45333)
2014 CS&P BLENDER...
2011 John Deere 135D Midi Excavator (A42742)
2011 John Deere...
2015 Freightliner 114SD T/A Vac-Con V311LHAE Vacuum Sewer Jetter Truck (A42742)
2015 Freightliner...
2006 Isuzu NPR Flatbed Truck (A42742)
2006 Isuzu NPR...
