Tractor Shopping and Lift Capacity
   / Tractor Shopping and Lift Capacity #1
monteu
Bronze Member
NE Kansas
Kioti DK5010
Ok......I am getting convinced by the family I need a tractor for our 9 acres. I have a machine shop and one of the requirements is I want to put forks on the loader to unload steel trucks when it is snowy because forklift won't work in snow. I need to be able to unload at least 2,000 pounds. I am partial to Kubotas for some reason.....but open to New Holland or something else. My main question is will a tractor in the 30 HP size range have that much lift capacity with the loader and be heavy enough. We don't get a lot of snow, but my driveway is long and if it is snowy or icy at all the forklift is out of the question.
   / Tractor Shopping and Lift Capacity #2
I think you are going to have to look at the 40+ tractor size to reliably lift that 2000 lbs with forks. The Kioti DK45se with its KL401 loader was rated 2762 lbs at the pins, to full height. so your 2000 lbs out on the forks is doable. Be sure to ballast the other end of the tractor adequately. The current Kioti NX45 is about the same. Several other brands will get you there too, but I can't think of any 30 horse tractor that will. Of course I could be wrong. But you need to set your sights just a little higher into the 40hp class of tractor I think.
   / Tractor Shopping and Lift Capacity #3
For 2000 lb plus loads of steel (beams, poles, 5x10 flats?) I'm thinking you'd be more safe getting a used forklift and then getting a small tractor for the acreage.
I have a forklift. This is just for the odd time that I need to unload a truck when there is snow on the ground.
   / Tractor Shopping and Lift Capacity #5
As Koua stated, nothing in the 30HP range is gonna cut it. You'll need a loader in the 40+ HP category. Forget New Holland, their 250TL loader won't do it. Kubota's LA1055 might not either.
   / Tractor Shopping and Lift Capacity #6
Then the bigger the better. Weight your tires too. I'd look for a used model with a cab since you'll be in the snow? Not sure where you live but I'm guessing it is colder there than here in Dallas.
   / Tractor Shopping and Lift Capacity #7
Sorry, phone made a duplicate
   / Tractor Shopping and Lift Capacity #8
Where I worked we had only a forklift to unload the steel off the trucks. Flat, beams, pipe - all tied down to pallets. After I had a couple near accidents - slipping/sliding into parked cars. The management got R-1 type front tires and since they were solid rubber - I drilled and installed large studs. Made all the difference in the world.
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A54757)
UNUSED LANDHERO...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2019 KENWORTH T680...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
