Dakota Joe
- Joined
- Apr 3, 2020
- Messages
- 29
- Location
- Berkshire County, Massachusetts
- Tractor
- Kubota L2350DT; Gator XUV 825i S4
Getting a new tractor as yet unseen and financing a bunch of implements to go with it. Would love to get your advice as a sanity check to make sure I am sizing the implements on the back correctly. (Salesperson is swell, but seems less detail oriented that I like to be.)
Tractor is Kubota L6060 with R3 Titan Multi Trac turf tires, rears sized 44x18-20 . Spec sheet lists rear tread as 52.2 or 56.3 inches. So I think the tread means centerline of wheels, and I add 18 inches to that, to get a range of 70.2 inches to 74.3 inches.
First question: I'm not going to take the tractor on steep hills and would like to use it sometimes on forest trails. So to keep flexibility to use e.g. six foot implements, it sounds like I should ask the dealer to do the setup at the narrower end of the range?
Second question: Is six foot the right width for land plane/grading scraper and box blade?
Third question: is 8 foot the right width for back blade and landscape rake?
Note that the driveways and paths we will maintain with these implements are only about 8 feet wide, certainly no more than 10.
Thanks in advance!
Thanks in advance!
