Backhoe Tractor RPM when using Backhoe?
   / Tractor RPM when using Backhoe? #1
Stimw
Elite Member
N. E. Florida
I have a Branson 3510. I got a deal on a new Jinma YW-6. I modified the subframe and plumbed it into the tractor hydraulics at power beound fittings. The hoe works great with the tractor RPM at about 1400 and running 2200psi relief pressure. I'm just wondering what others are setting RPM at with a Branson hoe.
   / Tractor RPM when using Backhoe? #2
I run my hoe at 1400 rpm as well and it works great. I don't know the psi though.
snoboy
   / Tractor RPM when using Backhoe? #3
Yup, same hear, about 1400rpm. I don't know the pressure though.
   / Tractor RPM when using Backhoe? #4
Depending on what I'm doin, 1200 -1500
This is with a 4720
For the most part I keep it around 1200 for loader work also.
Gene
   / Tractor RPM when using Backhoe? #5
Dealer told us 1200. Haven't bothered to try anything else. Works fine.
2010 Mitsubishi Fuso FE84D 16ft. Box Truck (A48081)
2010 Mitsubishi...
Sign Pole (A50860)
Sign Pole (A50860)
Pallet Fees (A50775)
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
STORAGE FEES (A51222)
2008 Utility Trailer VS2RA 53ft T/A Reefer Trailer (A48081)
2008 Utility...
