Tractor Radios..Which One??
   / Tractor Radios..Which One?? #1
Bret Mc
Bronze Member
Corner of Walk and Don't Walk, Ohio
Kubota B3030
Looking at radios for my new tractor(B3030), has anyone tried the Jensen compact radio setup? looks like alot of hole drilling to mount it, the speakers and antenna. The Tractor Tunes ROPS setup is nice but I don't think it would like tree limbs very well, and its expensive.The Roll Cover setups are ok but what about radio quality in these units? What are you guys using?
   / Tractor Radios..Which One?? #2
Since there is only one listener how about something like this:
3M Digital Work Tunes AM/FM Radio, Model# 90541-80000 | Hearing Protection | Northern Tool + Equipment
This style of head phones also acts like ear plugs, blocking outside sounds. Northern has some cheap ones in the stores as does Big Lots. They all come with 3 sizes of ear cups.
Skullcandy Store
I guess if you're baling hay the old fashioned way with helpers stacking on the wagon behind the baler you could mount these on the ROPS:
http://www.crutchfield.com/p_204MT8002B/Bazooka-8-Tubbies-Pair-Black.html?tp=3384
   / Tractor Radios..Which One?? #3
If you intend to listen with your tractor running, the Worktunes headphones are probably your best bet. Just think of how loud your tractor is, and then think of how loud the radio would have to be to hear it over the sound of the tractor. That adds up to a lot of potential hearing damage. The headphones eliminate that problem.
EDIT: Actually, "potential" is the wrong word to use. I should have said "guaranteed" hearing damage.
I have a set of the headphones, and they work OK. Not the best reception, but OK. Of course part of my problem is I like to listen to sports radio, and all of those stations are on the AM dial.
Another method I use is to get a pocket radio and get a set of earplug phones. I have a radio from Sangean (model DT-200X) that works very well this way. It is less cumbersome than the Worktunes, and the earplug phones block out a lot of noise. The nice thing is, it also has a built in speaker so I can use it to listen to ball games or music without the plugs when I am not on the tractor.
I guess I should have mentioned that I had a fender mount radio on the tractor I just sold (with an aftermarket stereo in it) and liked it really well, I even wear ear plugs when operating the tractor and can hear it fine and would really like to stay with this type of setup over the headphones,thats why I was asking about the Jensen compact and the roll cover radios. Thanks ,Bret
   / Tractor Radios..Which One?? #5
How was the AM reception on your radio?
   / Tractor Radios..Which One?? #7
Shucks, my tractor radio is a yard sale $2.00 AM/FM that I roof mounted with a couple of L brackets and wired to a pair of speakers.
Maybe not the highest fidelity, but it is stereo.
Antenna is an old spring mounted CB antenna for when I run under tree branches.
It receives all the AM and FM stations I'll ever want and actually I prefer AM chat shows and local news best, but that's my choice.
A radio wont care if it is in a Porsche or a tractor to do its thing.
Auto recycle yards would be a great source of inexpensive units.
Also you can eliminate speakers and use 8 ohm earphones if that is your preference.
   / Tractor Radios..Which One?? #8
I've got a recent experience to add to this thread. I had been curious about the radio headphones from Stihl. My local Stihl dealer had a set in stock, so I tried them out. I'll do a comparison to the Peltors (both analog and digital tuners) I've owned.
Firstly, the analog Peltors: These were the worst of the three. The analog tuning, was very picky to tune in, and drifted often. FM reception left a lot to be desired, and AM was darn near non-existent. The sound procuced is low quality, but for tractor work I guess it is OK. I would not recommend these to anyone.
Secondly, the digital Peltors: The digital tuner should have made tuning in stations much easier, but on mine the LED readout was off from the station frequency by about a half step. On FM, these never seemed to really lock in a station, unless that station was a high powered one. Maybe that was just the ones I had? I'm not sure. Again, AM was not received well at all. As with all of these (to some extent) reception was quite directional, so you had to plan your mowing pattern (as an example) so that you were facing the proper direction for any AM reception. The sound was still not very good, but OK.
On both versions of the Peltors, the antenna is placed very close to the headband. Most times I found that when the headset was fit to my head properly, the headband made the antenna bend to the side a bit. But, perhaps the high humidity had made my head swell a bit, who knows?
Lastly, the Stihl headset: These have an analog tuner, which can be a bit picky, but not as bad as the first set of Peltors. The reception on FM was much better, and not as directional. The AM reception, while still weak, was at least better than the Peltors.
Sound quality is where the Stihl headset trounced both sets from Peltor. Much better sound, with better response all up and down the spectrum. The antenna placement on the Stihls is a bit further from the headband, meaning that the antenna is allowed to stand up straighter, and do its job better. I'm sure it is not a lot of gain, seeing how these are all short antennas, but I think it did make a difference.
The weight of the Stihl set seemed to be a bit less than the Peltors, even though they also seemed better made. The battery cover is held by a screw, with a flip up handle that is nicely recessed when you don't need to remove the cover. Much more secure than the Peltors.
Another difference between the analog Peltors and the Stihls is something you may not even notice at first. Since neither one has frequency markings around the dial, how do you remember where your favorite stations are? The Peltor dial and surrounding area are both black. I suppose you could take a knife and make scars on the surrounding area to denote where to tune to your station, or take white liquid paper and place a dab of it in the proper places. Neither is the greatest way, but would work. On the Stihl headset, the area surrounding the tuning wheel is a bright orange. It is very easy to take a black permanent marker and just make a dot for each station's location on the dial. You could even use black for FM, and red or blue for AM.
So, to sum up this long winded post, the Stihl headset is (only my opinion here) a much better set than either of the Peltors, but there is a catch. While you can find the Peltors for maybe $50.00 or so, the Stihls run about $85.00.
I guess you have to determine for yourselves whether the increased cost is worth it to you. If talk radio is your thing, and you have a reasonably powered station close by, the Stihls probably are not worth the extra money. The more you are picky about the sound of your music, the more likely the extra cost may be worth it. In the end, the vote your wallet casts will probably be the deciding factor. After all, these are occasional use items, not a choice your life depends upon.
I am still curious about the fender mounted radios. Does using the tractor for a ground help the radio reception? In particular on the AM dial? After all, that is what your car or truck radio does and its reception is certainly better than the headsets (in particular on AM). I'm hoping someone with one of these can answer that question.
Anyway,thanks for taking the time to read.
   / Tractor Radios..Which One?? #9
Nice read.. I have the pelter, both kinds. The analog ones just died (I use these at home on the mower) and the digital ( use at work on a open station tractor) and only a year old the left speaker would stop once in a while and fire back up.
I agree with you about the peltors.
Gla d I now know Stihl makes a better one. Thanks for the info
DDT
   / Tractor Radios..Which One?? #10
I have the yellow digital worktunes for 2-3 years now use them when mowing on a garden tractor. They do cut fatigue vs no ear protection & are mobile, sometimes forgetting to take them off.
5 years with a REI fender mount radio mounted on a Gator.
4 years with a roof mount REI connected to a noise reduction headset mounted in a skidloader, only problem is wires take a beating. The hyd screech is effectively muted with this setup.
7 yrs with a cheap wal-mart radio mounted in my cab utility tractor.
Comfort Chute H Series Hoof Trimming Trailer (A50774)
Comfort Chute H...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2016 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2016 Mack CXU613...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
2018 Bobcat T595 (A50120)
2018 Bobcat T595...
