Tractor pulling left - how to fix?
   / Tractor pulling left - how to fix? #1
plaindave
White Lake, MI
Kubota B7800
My B7800 has started to pull to the left. If you let go of the wheel while going forward you'll be off in a ditch in no time at all. How do I fix this?
I was thinking I could back off the tie rod and start from square one adjusting the toe-in, but if that doesn't cure the problem which side should have more thread engagement to correct the pulling?
   / Tractor pulling left - how to fix? #2
1) are the tires all up to the same pressure?
2) is there a brake dragging?
3) When you drive straight, then stop without turning the wheel, are both front tires aimed in the same direction? Put a long straight edge across the tires at the mid point and site down it.
jb
   / Tractor pulling left - how to fix? #3
See if you've bent one of the tie rods. I had to have one of mine heated and straightened.
Tire pressure is good and I'm not sure about the brake. But I do like the straight edge idea. I'll check that out this afternoon.
Thanks.
   / Tractor pulling left - how to fix? #5
I agree with John on the brake dragging. If you bent a tie rod it should be obvious. Try locking the diff. and see if it goes strait. That should tell you if it is a brake or not
   / Tractor pulling left - how to fix? #6
Could also be a hydraulic problem in the steering. Does that have an orbitrol motor up by the steering wheel? They are known to do this when they go bad.
   / Tractor pulling left - how to fix? #7
No matter what you do to the tie rods, you can't make it pull to the left. Only caster, and camber can cause a pull, as far as alignments go.
There has to be a problem with the left tire, axle, spindle, steering box, or brakes.
As mentioned, check tire pressure first.
Make sure the Lt. brake is not hanging up.
Look for wear on the tires to see if they are scuffed, or worn uneven.
Stand in front with the wheels straight, and see if there is any uneven lean in the tires. Normally both will lean out on the top slightly, on a tractor. If they don't match, it could be something is bent. Spin the tires and make sure the wheel is not bent also.
Measure the wheel base, center to center on each side. Make sure the front wheels are straight when you do. Both sides should be almost even. Vehicle will always pull to the short side.
If you don't find anything wrong, switch the front tires, and see if the pull switches sides. This usually indicates a bad tire.
   / Tractor pulling left - how to fix? #8
Steering box could be the problem. Lift the front wheels off the ground with the bucket then see if the steering wheel pulls to the left.
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2007 Case 580M Series 2 Loader Backhoe (A53117)
2007 Case 580M...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
Wolverine Skid Steer Hydraulic Drive Trencher, New (A52384)
Wolverine Skid...
2005 MGL. ENGINEERING 7436 CONVEYOR (A53426)
2005 MGL...
2014 Club Car Electric Utility Cart (A51691)
2014 Club Car...
