Tractor pulled up on top of root ball
   / Tractor pulled up on top of root ball #1
nh1520
DuBois, PA
New Holland 1520
This past Saturday was a beautiful day here in PA and I wanted to catch up on some final mowing on our lower property. I was brush hogging the area that has several black locust trees approximately 12" in diameter. I nicked one locust and it moved pretty good and was dying anyway, so I figured I'd push it over like I've done several times before (I hate mowing around lots of trees).
I have always raised the loader up head high and pushed against the tree and usually just push them over and then use the loader to lift the shallow root ball up and out of the ground. I pushed on the tree and got it to start moving in the direction I wanted, backed up and lowered the bucket for the final push. This time when I backed up the tree fell away from me on its own and was nice enough to hook the underneath of the tractor with the roots and pulled me right up on top of the root ball. A definite 10 on the pucker scale. I wasn't in great danger of tipping over, but I couldn't move off the roots and was too high for the loader to lift me off. I immediately shut the tractor down in case I damaged a filter or hydraulic line and couldn't see it leaking. I spent the next two hours with a hand saw and bar cutting the roots and knocking the dirt off so I could see where I was cutting. I finally managed to get enough roots and dirt off that I was able to back off the ball with aid of the bucket. I was more mad than anything. The only damage was that I busted the plastic housing on the front driveshaft and bent the hydraulic piston for the power steering (which I was able to straighten). One of those cases where you have done something a hundred time before and its the next time that will get you.
No major damage done, I got the tree and learned a good lesson or two. Lessons learned: Don't hit a tall, skinny half dead tree unless you have overhead protection (I have a steel canopy top) and when pushing on a little one - make sure you get the bucket down quick and get back away from it in a hurry. Even the little ones can snag you at the worst time. Sorry no pictures (I never thought until I got off) but I don't forget the experience anytime soon. I wanted to share this scary experience.
   / Tractor pulled up on top of root ball #2
Glad you are OK - and glad the tractor suffered only minimum damage considering what could have happened.
Thanks for the post and warning on this. One of the reasons I got my tractor was to knock down some trees for clearing around our house, which I have been doing. I have learned several things, but, two of the most important have been (1) always check above for large dead limbs and dead tops still in the tree (due to ice - glad I have a strong canopy and this lesson didn't hurt too bad) and (2) keep a look out for the bucket shearing the tree.
I use to approach the tree with the bucket high for more leverage and level. As the tree would bend over and with the tractor moving forward, the bucket edge would often cut into the tree. One time, when knocking down a large pine, it sheared the tree in two. As it was falling over the tree got caught in some other trees sending the trunk sliding over the top of bucket somehow. For a moment it looked like it was going to keep on sliding over the top and catch me square between the eyes - really messing up my day /forums/images/graemlins/shocked.gif Good Lord was looking out for me as the tree fell on down and I was able to stop the tractor in time with no harm to myself nor the tractor.
I now have another area to check - see where the root ball might pop up - never even considered this.
Thanks again for the post.
-Eddie
   / Tractor pulled up on top of root ball #3
The tree wanted revenge. The same thing happens with bulldozers, the root ball will get stuck up between the blade and the grille.
Hydrema 912HM Haul Truck (A52384)
Hydrema 912HM Haul...
2015 Ford F-450 Bucket Truck (A53117)
2015 Ford F-450...
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A51247)
UNUSED INDUSTRIAS...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
John Deere 772-A Grader (A52384)
John Deere 772-A...
40' CONTAINER (A51248)
