Tractor Positive Camber - Why?
   / Tractor Positive Camber - Why? #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
Does anyone know why tractors are designed with such extreme positive camber (front wheels sloping out at the top, in at the bottom)? It seems that is the last thing one would want, considering the weight that the wheels have to support, especially with FEL work, not to mention that positive camber makes tipping over considerably easier. I guess it makes initiating a turn easier, but at 3MPH, who cares?!
Is there actually a good reason for this, or is it just tradition left over from before they invented power steering?
Jay
   / Tractor Positive Camber - Why? #2
actually, i belive it is to help the front end carry the load, and to make it much easier to steer.... the tire being tipped keeps the kingpin angle closer to straight, and still pointed at the center of the tire.... this is much more important now, then in the older tractors without power steering... with an fel, the load on the steering componets is quite high, and if they were asked to control a tire that stuck out to the side, may fail very early in life....
this also prevents torque steer in rough terain, keeping things much easier on the knuckles
   / Tractor Positive Camber - Why? #3
Yes, kingpin pointing to the center of the tire patch is the reason. If it didn't line up, the wheel would have to roll as well as pivot in order to turn. It also puts the weight directly on the axle piot vice offset from it.
Harry K
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2025 AGT YC-26G (A50123)
2025 AGT YC-26G...
2021 Krone ECTC 400 (A50123)
2021 Krone ECTC...
2020 CATERPILLAR 299D3XE SKID STEER (A52705)
2020 CATERPILLAR...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
