Tractor mounted concrete/cement mixer
   / Tractor mounted concrete/cement mixer #1
peterb33
Midlands UK
Mitsubishi MT 180. Hanomag R19
Hi,
Located in the UK and just looked at a Teagel tractor mounted concrete mixer but it looks far too big for my MT180. Question is, is there a tractor mounted pto driven mixer available which is suitable for compact tractors?
   / Tractor mounted concrete/cement mixer #2
I have a 3 point mixer. I have thought about rigging one of my compact tractors, about the size of your MT180, to run it, but I am not convinced they could handle the load safely. I run it on my IH284, but prefer it on my much bigger IH464. I think I would end up requiring a lot of extra nose weight on the tractor, and would be at risk of damaging things, if the tractor would even lift the full mixer. Mine mixes 6 60 pound bags of pre-mix at a time without spilling; it would hold more were I to set it up to tip upward at a steeper angle. It has a large drum, probably 10 cubic feet or so.
I have mixed feelings about the usefulness of mine. For doing small pours, the setup and cleanup time of the tractor mounted unit isn't worth simply doing the mixing in a wheel barrow. If not mixing more than 15 or so 60 lb bags, the wheel barrow is as fast or faster. For pours over 1.5 yards or so, there is simply too much handling of bags to be very reasonable or enjoyable to me, and I'd rather have it trucked in or brought in some way where I don't have to manually shuffle the entire mass of mix by hand. I buy bagged concrete mix, because it is less work to do that than shoveling aggregate along with handling bags of portland cement.
I don't have one of the electric or gas powered mixers, but have used them, and think that is probably a more versatile option than the tractor mixer, unless you know that your pours will be in locations inconvenient to access with the portable mixer or wheelbarrow. This is the biggest advantage of the tractor mixer, from my perspective: It makes it very easy to mix at a central location and make pours in spots away from hose access or electricity.
   / Tractor mounted concrete/cement mixer #3
I just read the capacity for the three point hitch lift capacity and 1,430 lbs is listed for the S373-D.
I built a stand for a three point mixer that accepts 1 bag (40 Kg) of cement and the appropriate gravel. My friend took it off the stand and has mounted it to his Hitachi 40 Excavator driven hydraulically. He used it to reach some rather tall forms about 5 feet off the ground for the footings of a hay shed. I want to adapt this mixer to this little tractor because I believe it will handle it no problem.
2017 Ford F-450 XL (A44501)
2017 Ford F-450 XL...
53’ STEP DECK  MIXER TRAILER (A45046)
53’ STEP DECK...
John Deere 5105 Tractor (A41660)
John Deere 5105...
New/Unused 10ft x 20ft Single Garage Metal Shed (A44391)
New/Unused 10ft x...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A44571)
2015 Ford F-550...
2020 Ford F-150 XL (A44501)
2020 Ford F-150 XL...
